johnpstoll
I need some advice on riveting on the tank. I just started my first tank and finished back riveting the stiffeners. About halfway thru I checked the rivets and they didn't seem to be setting flush. So, I made sure to hold down the skin and stiffener onto the back plate when I riveted. It didn't seem to make any difference. I can run my finger across some of the rivets and feel the edge.
I've been reviewing some of the other posts on the forum and had a few thoughts. I thought maybe the dimples aren't deep or sharp enough. Too much pressure on the rivet while setting? The instructions on the c frame say you can't over dimple, but can you under dimple? I usually run the dies together and then give them another 1/4 turn before I tighten them.
I'm debating whether to stop before I install any ribs and rebuild. Any advice on what the problem is? Am I being too OCD?
Here are a few pics.
