I have a cheap Dymo label that has been working well for years but now time to label the wires and eventually panel.
My Dymo has extra small font, which 0.078" tall characters, small enough to go around circumference of 20 awg and likely 22 awg with out overlap.
All I need is two or three sizes of clear heat shrink.
I know you can get heat shrink label maker can print directly onto . The smallest label I found was 5.8mm (flat). This would go around a 0.075" diameter wire, or about 16 awg. I don't have many of those. If I got a label maker I suppose I would want that option for larger wires. You then have to stock different sizes of heat shrink label maker cartridges.
24 awg is going to be challenge with my label maker so one that can do smaller fonts is needed.
For the Panel - I will want WHITE on Clear and best quality and flexibility in font size and style. What kind of label maker and what kind of label material for panel. My plan is paint panel labels, cutout, attach with sticky back, shoot clear over it? Not sure how two part urethane does with label maker tape.
