backcountry
It would be a lot of work but was wandering if anyone has done it.
I once found this blog, legacy RV-12 with 912iS, from my point of view well engineeredIt would be a lot of work but was wandering if anyone has done it.
This on an RV-12?Flew this morning…. I think 10th flight since installing 3-blade carbon fiber E-Prop. Climb rate with one person and 1/2 fuel was 1200 FPM. Flew reduced power setting at 5050 RPM and saw 126 MPH TAS burning 4.4 GPM Costco 93E10 MOGAS. 3-blade carbon prop is incredibly smooth. Perfect combination of engine / airframe...
Yes, my RV-12 is SN 120058 with 980TT... Engine runs like new. 5500 RPM cruise yields 140 MPH TAS. Photo attached is 5300 RPM / 136 MPH TAS which is where I usually operate when air is smooth. I use MPH for speed and nautical miles for navigation.This on an RV-12?
What setting did you go with on the e-prop blades?Yes, my RV-12 is SN 120058 with 980TT... Engine runs like new. 5500 RPM cruise yields 140 MPH TAS. Photo attached is 5300 RPM / 136 MPH TAS which is where I usually operate when air is smooth. I use MPH for speed and nautical miles for navigation.
Blades are pitched to 26 degreesWhat setting did you go with on the e-prop blades?
Thank you.Blades are pitched to 26 degrees
Yes, I did it!It would be a lot of work but was wandering if anyone has done it.
