I'm getting mixed signals on providing the static source to the GTX-345. I have heard that you can connect the static line directly to the transponder and others say that you need a altitude encoder like the Garmin GAE-12 or some other RS-232 unit. I have also seen that people say that if you pull out the transponder that you have to recheck the static system for leaks. This sounds like the static line has a direct connection. Which is true and what is the best option? Thanks, Tom
