Back in 2014, while assembling the kit I decided to use a ULPower 260is engine as I wanted digital engine control and Vans was not blessing dual EFIS in the panel because of electric load. Yeah back then I had the same response from the naysayers that I was crazy and the 12 was not designed, and could not accept any engine other than the ULS912. If the 912is had been available, I am pretty sure I would have just went with the munchkins, installed the IS engine and been happy ever after, other than the continuous SBs from Rotax, expensive parts, and poor factory support.
Fast forward. I now have 915 (6-16 first flight) trouble free hours on the the bird with my 260is. I just get in it and go.
No radiator, carb, floats, engine driven fuel pump, hose replacement issues. No burping the oil receiver. No annoying clunk on shutdown.
Weight is 805lb with a 6lb chunk of tungsten on the stabilator bulkhead. The weight could be eliminated with a shorter engine mount.
I installed redundant engine computers/sensors, dual alternators.
Top speed is 5 knot less than Vans published, but I can run that all time if desired.
Routinely climb out at 1000fpm
