It is not normal, not good. I'd find out how CO is getting into the cockpit and seal it up. And of course confirm it's not an exhaust leak.I bought a CO detector and it reads a small level of CO in the cockpit if the air vents are closed. Pulling the cabin heat knob actually decreases the level, but doesn't go away. Is this common with RV's? Anyone else have a CO detector in the cockpit? Thanks.
Thanks. I'm between 11 and 20..My portable CO detector in the 7 always read around 2 with the vents closed.
Thank you Paul. We did find a leak in the exhaust, but that didn't fix it. I'm going to buy a second CO detector and position them in various differest spots in the cockpit to try and find the source. I hadn't thought of the stick boot hole. Thanks.I get none on my detector. Possible sources... CO will be sucked in through any unsealed holes in the firewall. I've also heard of it coming in from under the seat pans and up through the stick boot holes. Another place is around a poor canopy seal. Finally there are some potential leaky areas on the very aft end of the fuselage where the bottom rudder hinge is. Also make sure you have no apparent leaks around the exhaust. Only place should be out the aft end of the pipes.
Thank you. We did find an exhaust leak and fixed it, but that didn't stop the readings. Strange.It is not normal, not good. I'd find out how CO is getting into the cockpit and seal it up. And of course confirm it's not an exhaust leak.
As a data point, I only see CO on my detector when I've got my back to the wind while running on the ground, or someone in front of me is blowing CO in my direction. In flight, I never see CO.
Thank you. I would not have thought of that.
I use the Forensics CO detector in the RV9 and it always reads 0.I bought a CO detector and it reads a small level of CO in the cockpit if the air vents are closed. Pulling the cabin heat knob actually decreases the level, but doesn't go away. Is this common with RV's? Anyone else have a CO detector in the cockpit? Thanks.
Those holes are hard to seal...One other area that's been reported here is the holes for the flap pushrods.
I can't comment on whether it is a culprit for CO but either way there's a worthwhile mod if only to keep the cold air from blowing up past your sticks: Thread 'Aileron Push Rod Boots?' https://vansairforce.net/threads/aileron-push-rod-boots.156550/JCTYM... The stick boot area is a possible inlet but I don't know what you can do about that spot. Seems to me the CO would be getting sucked in at the wing root area then on into the subfloor area [...]
That seems like a simple fix on the 7A, but it's a little more challenging on the 7. The weldment for the tail gear sticks down through an elliptical hole in the tailcone skin. I suppose you could lay a fillet of pro seal in there?"...I recommended he seal up the aft end of fuse between rudder and aft fuse... problem solved..."
Good idea, but I'm wondering exactly how to do that. The exhaust pipes are fixed and bolted on. I'd hate to buy new ones or have a welder change the angle only to find it didn't fix it. I wonder if there's any "add on's" that can be attached temporarily for a test.I would first make sure the exhaust are pointed DOWN. A friend here had +CO in the cockpit. I recommended he seal up the aft end of fuse between rudder and aft fuse... problem solved.
Thank you. I'll look into it.It's been a long time since I finished building, (12 years), but seems I remember a connection of some kind that enables them to be rotated then secured again. I have the standard Vetterman exhaust that came with the kit. Edited: I found a picture of the joint I'm referring to. I think you can adjust at the area where there are springs on the bolts.
Often, during take off and landing, CO enters the cabin through the flap rod actuators, when the flaps are up, the hole is covered. During taxi, depends on the relative wind, but that is the usual time there is CO with on appearant leak noted.I bought a CO detector and it reads a small level of CO in the cockpit if the air vents are closed. Pulling the cabin heat knob actually decreases the level, but doesn't go away. Is this common with RV's? Anyone else have a CO detector in the cockpit? Thanks.
Interesting. I've owned it since October so I'm relatively new. I'll admit that I've never seen it with the flaps up, as I always keep them down on the ground so folks don't step on it. I didn't know the holes were covered in flight. I'll have to look. But no, I get CO readings in cruise consistently.Often, during take off and landing, CO enters the cabin through the flap rod actuators, when the flaps are up, the hole is covered. During taxi, depends on the relative wind, but that is the usual time there is CO with on appearant leak noted.
DAR Gary
I tried taping all around the flap actuator rods and did a flaps up takeoff and landing as a test. No affect, I still got the CO reading in the cockpit. So that's not it. I'm now thinking I might need new exhaust pipes that stick out further and point down, or maybe there are extensions that can be added on.Often, during take off and landing, CO enters the cabin through the flap rod actuators, when the flaps are up, the hole is covered. During taxi, depends on the relative wind, but that is the usual time there is CO with on appearant leak noted.
DAR Gary
