Juliet Delta
Who uses corrosion x and where? Does anyone spray it on the back of the panel for electrical connections
CorrosionX and ACF-50 both work to prevent corrosion...BUT...there are a few things to know.Who uses corrosion x and where? Does anyone spray it on the back of the panel for electrical connections
Hate the player, not the game.I will never ever buy another airplane that has been treated with that stuff. On my second now, always leaking black stuff at skin joints etc even after 20 years.
I’ll see if I can round up a picture of my 172 that was painted after CorrosionX application, by a reputable paint shop. The paint came off in pieces up to 6” across. The paint was full adhered to the primer but the primer didn’t bond to the aluminum. Yes, they did their standard paint prep before painting.Hate the player, not the game.
CorrosionX, ACF 50, similar are supposed to be atomized when applied. When properly set up, you can see the fog vent from the opposite send of a wing when applying. It atomizes that well. Also, it doesn't take much; probably just over a pint to fog a typical two seat RV. More isn't better. After some initial wipe downs, I had zero weepage after a couple of regular aircraft washings
And yes, I've had aircraft painted after applying oil preservatives though I did time it to be done at the end of my biannual fogging interval. Standard proper paint prep led to zero issues. Over application/treatment could have led to the known, related issues.
If you don't want prolonged weepage, try Dintrol. It is a very good product that dries.
Ultimately, I'll do extra cleaning rather than leave my airframe "less" protected. In Hot and Humid Flor-e-Duh, where it's not unheard of for certified aircraft to be economically totaled from corrosion, it just makes sense.
I don't live in FL and don't plan on it, except when sailing, and my boat is mostly frozen snot (aka fibreglass)Hate the player, not the game.
Not afraid of CorrosionX at all...just remember removing the paint AND primer with an ordinary broom, right down to the metal.Fogged every other year for a few decades. Painted after ~10 applications. Not one paint blister. Improper application and/or poor workmanship can taint anything. I'll state again, if you afraid of oil based perservatives, Dinitrol is pretty awesome as well.
And BTW if you've got anything with 7075 as part of the construction, your need to utilize additional levels of corrosion prevention is an order of magnitude higher. Several times more than a $25K "chance" involving just paint.
My comment would be that likewise, fogging is the proper method. I use ACF-50 and they produced a DVD and youtube video that shows proper application. I bought the full application kit which includes the correct sprayer and (very) long nozzles and tubes to extent as long as the individual wings. If whats being used for application is the spray bottle the its being done wrong. Fog, not spray, and it won’t seep.Fogged every other year for a few decades. Painted after ~10 applications. Not one paint blister. Improper application and/or poor workmanship can taint anything. I'll state again, if you afraid of oil based perservatives, Dinitrol is pretty awesome as well.
I would disagree as we had our 172 fogged by a reputable company using the proper equipment and it still wept. Good news is the CorrosionX is clear instead of the red ACF-50…much harder to notice.My comment would be that likewise, fogging is the proper method. I use ACF-50 and they produced a DVD and youtube video that shows proper application. I bought the full application kit which includes the correct sprayer and (very) long nozzles and tubes to extent as long as the individual wings. If whats being used for application is the spray bottle the its being done wrong. Fog, not spray, and it won’t seep.
My beloved "bucket of bolts" was a Miami find.. had to corrosion proof with corro-x or loose all resale value in a few years. When it came time to do some touch-up painting I nearly blew my brains out in frustration. I honestly could use a complete spinner to tail repaint but sincerely believe it's not possible without a really experienced pro, fully informed of the past foggingHate the player, not the game.
