Hi All, thought I would share some of my misfortune with the community to raise awareness.
I purchased a YIO-390-EXP340 Thunderbolt engine through Van's for my RV-14A. I had first engine start and first flight last July, 2024. As of today I have put about 138 hours on the engine. This morning when doing a runup prior to takeoff I experienced a great deal of vibration and shaking with my number 2 cylinder going cold at the same time. I aborted the takeoff, came back to the hangar and decowled to see if I could find the problem. I discovered a great deal of oil and my exhaust valve shroud tube bent. This appears to be the classic stuck valve.
I purchased the engine in 2022, so I was sweating bullets whether it was still under warranty. Thank goodness it was, but just barely. Lycoming has entered a service request for a new cylinder kit with associated other parts, and now it is up to me to contact an authorized distributer for the parts before I can start the repairs. In the meantime, there is an awful lot to undo to get the cylinder off. When I put all that together in the first place, I tried to do the best quality work and make the baffles air-tight because I wasn't expecting to have to have to take anything apart for many years. Now, just 8 months later it has to come apart.
I mention all this because while talking to Lycoming they said that when making the repair, they recommended performing mandatory service bulletin 388C on the other cylinders prior to placing the plane back in service. This service bulletin is for determining the exhaust valve guide condition, and if found to be too tight, then there is a process to ream the valve guide (service instruction 1425A). There is yet another service instruction, 1193A, that talks about additional inspections in the event of a valve failure such as what I experienced.
I have made every effort to follow the Lycoming manuals as closely as I'm able to ensure best performance and longevity. I asked Lycoming whether it was possible I wasn't doing something right that could have caused this failure, and was told no, that even with improper operation, 138 hours isn't enough time to cause a stuck valve and therefore it's likely to be a manufacturing defect. All this to say that I highly recommend that folks read and perform service bulletin 388C on their new and very expensive engines. Do this, and you may avoid the heartbreak and downtime that I am going through now.
