Hello everyone,
I'm in the process of adding a level button (SV-BUTTON-LEVEL) to my RV12. I opened the 37 pin connector for the back of the Skyview classic and found that there's already wiring on pin 26 (dim out). It's indicated as an open position on the RV12 wiring diagram. Without doing more investigating it looks like it lands back in the AV-5000A but I'm not sure what pin unless I pull it apart. Two questions:
1. Does anyone happen to know where this wire leads or ends?
2. If I don't connect the dim wire on the level button I'm assuming I'll either get no backlight or full backlight. Does anyone know if this is a correct assumption?
Thanks for the help! Jonathan
