This is not really clear how the laser is used.I pulled from a couple ideas here on VAF. I used Van's prop pitch tool along with a digital level with integrated laser. Chocked all wheels to prevent movement of plane. I used the longerons to zero out the level, and a second level on the prop hub to maintain level there. Placed the level on the tool and set to desired pitch. I then placed some masking tape on the ground and marked the location of where the laser was pointing. Pulled the next blade around, attached the tool and level taking great care to ensure all locations were exactly (or as close as possible) as on the first blade. Lined up the laser with the first mark on the ground and verified on the level's readout that the pitch was the same number of degrees. For fun, I pulled the first blade back around to confirm a match. I did the math and determined the accuracy of this method was about as close to a perfect match as one is going to get.... Somewhere in the neighborhood of a small fraction of a degree. I hope that all makes sense.
The laser-level hangs on the pitch tool, which hangs on the prop blade. The laser points at a spot on the ground. Mark the spot on the ground, remove from blade #1, pull next blade around to the same position, and hang it on blade #2. Adjust the pitch of blade #2 with the laser-level attached to it, until the laser points on the spot on the ground....this indicates the blades are pitch almost exactly to the same angle. More accurate that what the readout on most digital levels will show. Unless you spend a bunch of money on a level that gets down to the .00X range.This is not really clear how the laser is used.
Can you post a link to the laser you use.The laser-level hangs on the pitch tool, which hangs on the prop blade. The laser points at a spot on the ground. Mark the spot on the ground, remove from blade #1, pull next blade around to the same position, and hang it on blade #2. Adjust the pitch of blade #2 with the laser-level attached to it, until the laser points on the spot on the ground....this indicates the blades are pitch almost exactly to the same angle. More accurate that what the readout on most digital levels will show. Unless you spend a bunch of money on a level that gets down to the .00X range.
Cant find the one that I used but this one is quite similar.Can you post a link to the laser you use.
Ok, that makes sense how you are using it.
