I think it was working when I bought the airplane and did the pre-buy. It has 61 hours on it and was not flyable when I purchased it.Have you figured out why it's sticking -- Master Cylinder failed, pivot bolt/nuts too tight, etc.?
If you think it's the master cylinder, check out MATCO's website -- example: https://matcoals.com/wp-content/uploads/2023/02/3D-MC-4FL.pdf
Yes - it's a Matco "primary" (nee Master) cylinder.I think it was working when I bought the airplane and did the pre-buy. It has 61 hours on it and was not flyable when I purchased it.
I rebuilt the calipers thinking there was a leak on the right side. I subsequently learned the brake line was leaking at the swedge and replaced the entire line.
I recently put the pilot seat back it to test the height of the control stick and clearance to the new panel with the new stick grip and had my feet on the pedals for the first time since I purchased it.
I’m just fixing all the squawks now.
Is this a Matco brake? I do not have any markings on any of the 4 units
Manually pull the pedal back to see if its mechanical binding, or hydraulic (piston/seal) binding.Yes - it's a Matco "primary" (nee Master) cylinder.
The wings have been off for almost a year. This has been rolled back and forth to the avionics shop a couple of times. The rudder pedals are what they are from pushing it into my corner of the hangar.IF it is in fact the master cylinder stuck , the return springs mentioned above might do the trick. On looking at your original post pic again. It looks to me that the rudder and/or tailwheel position is holding the pedals in a different position from "neutral" Which is entirely acceptable especially on a tailwheel plane. Maybe just my 77 year old eyes!!! A little right foot may correct your problem.
are you sure it is stuck down? the pedals are not supposed to be in the same orientation relative to the bars. measure the exposed rod length to confirm. tough to tell from a pic, but they look the same.View attachment 82533
Rv7. I know I’m going to end up doing all 4. The question is where do I find the appropriate illustrated parts catalog?
Agreed. This install needs a complete work over."Get rid of the bull5h1t..." as my Dad used to counsel me. Order a set of brake lines from TomS -- Reservoir, to Pedal, to firewall. Do it right, once.
And FWIW, the 90° AN-NPT elbow fittings aren't clocked correctly - you can see some hose chafing there.
There's also a “single bolt” mod that you could do that eliminates binding.
Secondarily, many folks answer to brake pedal sticking is springs. You won’t need them if you use the single bottom bolt and align things correctly.
I bought some Royco 782 after looking at my Vans -7 thumbdrive.What brake fluid did you put in? Wrong type could seize the system.
Looks like it. It by itself isn’t a total fix though. You still have to insure there isn’t any binding in the system and correct that. As discussed before, it’s a poor design from the start and regardless will side load the piston and eventually the seal will leak.Hard to tell for sure, but from looking at the left pedal it seems like this installation might already have a single pivot bolt there:
