Has anyone tried strip caulk?I’ve installed these Van’s upper cowl inspection openings. What is a good way to seal them?
What’s Cth6 and where do you get it? Didn’t get and definite returns when searching.I used the Cth6 method. Thin rubber sheet from Amazon. Traced around the panel and cut out the middle. Used 3M weather strip adhesive with a weight on the panel till it cured and trimmed around it. Heated a nail to poke the fastener holes open. It installed pretty well and was very simple to do.
