I am planning my RV14 Electrical system for an electrically dependent engine - it will be IFR, so some items of avionics will be essential for all phases of flight.
The question is:
Is it a bad idea to have some avionics (such as the PFD) always powered on, even when the master is turned off (like in a smoke in the cockpit scenerio).
I am concerned that if i did have smoke in the cockpit, and it happened to be the PFD or a primary COM etc, that i could not de-power these devices with the normal "master off" approach. Similarly, these are really required to fly safely in IFR, so don't want to be in cloud and end up running only on the battery of the G5 and unable to get back down.
OR is this a non-issue that i shouldn't be concerned about? Would these items simlpy burn out their fuse is something internal started to smoke? (or impossible to know).
Some background:
I am planning to have:
- A main bus (32 position fuse block), which will power all the non-essential items, as well as the secondary power feeds to essential avionics.
- An engine bus (20 position fuse block), which will power the EFI system.
- Another power distribution device for primary power to essential IFR avionics.
The question is:
- Is it a good idea to power the essential IFR flight instruments off this engine bus? (3rd page of the attached) or
- Have a second "Essential Bus" which is made up of traditional breakers / copper bus bars, to allow me to depower any or all of these essential items as required?
If so,
- Can this "essential bus" be powered directly off the main bus (2nd page of the attached) with a short feeder (aka the engine fuse block and traditional breakers physically next to each other), or
- Should this "essential bus" be fed from the appropriate contactors via direct feeds (1st page of the attached).
I also warmly welcome any additon feedback to V5356.2 of my proposed system which has been keeping me up at night!
Side note:
The indenendently fed essential bus, would allow me to potentially split the EFI components across 2 engine busses (potentially protecting against bus failure or shorts), however i am not sure how to approach injector power, which only have a single feed to them. This is a still outstanding concept if anyone has any thoughts in dual feeding EFI injectors.
The question is:
Some background:
The question is:
If so,
Side note:
