BLittleton
Howdy folks. I have an IO-360-A3B with a Dynon engine monitor. I'm getting a continuous oil pressure fluctuation of +- 10 PSI or so...always withing the green range. But I can watch the OP dance up and down the entire flight.
I'd like to know if this is perhaps normal? The engine monitor is so much more precise than an old gauge...perhaps this is just the way it always works for all engines but the fluctuation is too small for an analog needle gauge to see???
If it is a problem, my best guess is perhaps the oil pressure relief spring has the ball bouncing on the seat. If so, do I need a stronger spring, or a weaker one?
