I have a Key100 on the bus feed and it works every bit as well as the shunt off the alternator output.
It is awkward to wire, and awkward to mount, so I was looking at other things for the new build.
This device comes ready with a plastic shell and mount, but I haven't worked out the physical wiring connections yet. It has 5 pins, but only three are the ones we typically use; the other two can be ignored.
I think I'll put a current sensor inside the fuselage on the 8AWG wire coming into the fuselage and skip putting a shunt out on the firewall from the alternator.
LEM HO 50-S
It says it is 50A, but that is AC RMS, it is +- 100 for DC current with 16mV/A sensitivity similar to the Key100.
Something to think about.... data sheet attached.
LEM HO 50-S
