Just a little clarification here so others don't get confused. An RV-12 is an LSA, Light Sport Aircraft. What you are really asking about is converting from an experimental LSA (E-LSA) to a "special" LSA (S-LSA). In other words converting from an Experimental Airworthiness Certificate to a Special Airworthiness Certificate. It is the Special Airworthiness Certificate that allows you to do commercial operations.hey guys is there a way to change the registration classification from "experimental" on rv12 to "light sport" so it can be used for flight school. maybe vans has a program for helping with this.
Bob, while the gist of what you wrote is correct, terminology is important in order to not confuse folks. An Experimental Airworthiness Certificate IS a Special Airworthiness Certificate as well. AT the top level, there are two types of Airworthiness Certificates - Standard and Special.Just a little clarification here so others don't get confused. An RV-12 is an LSA, Light Sport Aircraft. What you are really asking about is converting from an experimental LSA (E-LSA) to a "special" LSA (S-LSA). In other words converting from an Experimental Airworthiness Certificate to a Special Airworthiness Certificate. It is the Special Airworthiness Certificate that allows you to do commercial operations.
My understanding is that conversion is a one way operation. My RV-12 started life as an S-LSA and was converted to an E-LSA. So even though it is factory built its configuration is no longer necessarily the factory configuration that qualified it for a Special Airworthiness Certificate. Once it became experimental it is no longer configuration managed by the FAA and so no commercial ops allowed.
What if I put it back in factory configuration? Well, who is going to certify that? Certainly not the factory. Bottom line is that it is impractical to try to go back to a special airworthiness certificate.
The factory IS the only one who can do this. And the aircraft MUST have started life as an S-LSA.What if I put it back in factory configuration? Well, who is going to certify that? Certainly not the factory. Bottom line is that it is impractical to try to go back to a special airworthiness certificate.
Yep, I agree! Words are important, especially when dealing with a regulatory government agency.Bob, while the gist of what you wrote is correct, terminology is important in order to not confuse folks. An Experimental Airworthiness Certificate IS a Special Airworthiness Certificate as well. AT the top level, there are two types of Airworthiness Certificates - Standard and Special.
Because this is Van's Air Force, and even the simplest of topics can drawn out way too long...hey guys is there a way to change the registration classification from "experimental" on rv12 to "light sport" so it can be used for flight school. maybe vans has a program for helping with this.
