RV-8 with an aft battery and battery contractor. I'm going to put the lighting controller, the ADAHRS, and a few other boxes aft. Maybe a COM2 remote radio aft. Maybe keep the audio controller aft as well if I remote it. I'll feed the aft circuits through a fuse block.
I need a ground bus plan. I don't want to run all the ground wires forward to the firewall, and I don't want to run all the forward circuit ground wires aft.
So maybe two ground tab plates. One forward at the firewall, and another aft tied to the battery ground. Any box that has audio associated in any way can run its ground aft to avoid loops. The only thing forward with audio in this setup is a COM1/Nav radio, and the G3X display. Everything else up forward can ground up forward at a firewall tab plate.
I like having the lighting controller, audio panel and remote radio aft, since then the headset jacks and stick button wiring and a lot of other wires don't have to go across the spar.
I know there are a million opinions on all this. What I'm really after is has anyone split out the grounds this way?
