MattChaloner
Hi all,
I’m just getting into the horizontal stabiliser on my build and have started preparing the spar caps for the HS1002 rear spar. I’ve noticed that the spar caps sit proud of the spar flange by around 1/16” of an inch, whereas I was expecting them to be flush as they were on the vertical stab.
It’s going to take a long time to remove the material along the length of both spar caps so I wanted to check before I go any further whether anyone else has found the same, and if I should be concerned?
Thanks as always!
Matt
Thanks as always!
Matt
