MattChaloner
Hi All,
I’m now progressing my empennage kit and have had inspector sign off to rivet the skin in place on my vertical stab. I missed up 1 of the rivets so I drilled it out and put another in before moving on. Having now riveted the bottom nose rib in place I’ve noticed that the “redone” rivet is not quite sat right… it’s pushed the rib flange out (presumably when I tapped the first rivet out with a punch after drilling the head)
Does anyone have a suggestion on what I should do with this given the limited access I now have - or do I need to drill out every rivet I’ve set so far (43 of them!) plus the middle spar rivets (another 3) to take the skin off and straighten the nose rib?
I’m just a bit concerned that I could make things worse in the process of drilling out those 46 rivets!
Thanks in advance
Matt
Thanks in advance
Matt
