You don't need heated pitot tube for IFR. In fact you get into icing and need your heated tube in an RV you are doing something wrong and need to exit to warmer temps or clear of visible moisture, eg clouds, drizzle, rain.
Yes I am aware you can get into mild light rime ice that is no threat... on the other hand Ice should be avoided. But if your pitot is ICED OVER, you have BIGGER problems, like your prop, flight surfaces, controls, airframe. ICE = BAD in small SE GA planes. You are by authority of "the adminstrator" forbids, you to fly into known ice in any aircraft not certified for known ice. Once you are in it, it's known.
My point is legally, you don't need heated pitot. Fly clear of clouds OR in temps ABOVE freezing and not under a warm front overtaking sub freezing temps (ie freezing drizzle and rain).
Yes - Practice in VFR with a Safety Pilot of CFI or CFII? Yes. You can log it as simulated instrument, towards an IFR rating. What about filing an IFR flight in VFR plan or filing and flying actual IMC? No and Yes. It is possible. This is what Google now AI says:
"QUOTE
Yes, it's possible to fly a Light-Sport Aircraft (LSA) under Instrument Flight Rules (IFR) in some cases, but there are restrictions.
Restrictions
- Manufacturer preference: The manufacturer may not allow IFR flight.
- Operating limitations: The aircraft's operating limitations may prohibit IFR flight.
- Equipment: The aircraft may not have the required equipment for IFR flight.
- Pilot rating: The pilot may not have an IFR rating on their pilot certificate.
- Skills and medical: The pilot's skills and medical condition may not be suitable for IFR flight.
- Maintenance: The aircraft may not be properly maintained for IFR flight.
Required equipment Two-way communication equipment, Navigation equipment, Gyroscopic rate-of-turn indicator, Sensitive altimeter, and Artificial horizon.
Relevant regulations
- FAR 91.205 lists the equipment required for various types of flight.
- The ASTM F.37 industry committee has been working on an IFR standard for LSA producers.
You can consult your aircraft's operating limitations to determine the conditions under which it can be flown under IFR.
END QUOTE"
Keep in mind MOSAIC is coming. Not sure what that will be. Either does the FAA apparently. Formally Std Cat planes widely used in IFR may become LSA's by definition.
