I'm about to hang my engine, then attach my tailcone. First, I decided to re-pressure-test my fuel system before I make it any harder to get to the connections to tighten them. After connecting the firewall supply and return lines together, and capping the tank return line connection, I applied 40 psi to the tank drain connection and soap tested almost* all the connections, tightening a couple. (The fuel tank isn't involved in this test - it's not in the airplane.) After a couple of days, it leaks down to 20 psi.
*I can't get to the two connections under the firewall shelf behind the rudder pedals, to either soap ‘em or tighten them. I’m thinking of removing the pedals to gain access; this would also make it much easier to get a good paint job on the inside fuse walls and center console, since the pedals would partly be in the way. Not sure I’ll be able to remove the pedals after the harness goes in; it’s relatively easy now, 30 minutes out and maybe an hour to get 'em back in; I haven’t filled the brake lines yet.
So, advice please: did you pressure test your lines? What’s “good enough”? Another builder told me not to worry about this - “there’ll be leaks no matter what; just fix them when you find them.” After trying to get to those two connections under the shelf, I dread having to fix a leak there. Also, any pointers to good tools (beside crowfoot wrenches, which I have, but barely fit) for tightening those fittings? Thanks!
