I started to do it exactly as you show. I actually ran all the wires. Eventually I changed my mind and put the battery on the firewall. You might consider putting your battery on the FW and using a light battery like an EarthX - this will save a lot of weight, and make everything a lot simpler. Total weight will be lower, and if you need weight in the back, it's easy to throw a tool bag back there when needed.
