A few points to ponder:
1. All experimental airplanes have differences in pitot/static configuration and plumbing. This means each airplane has a unique static source pressure error, therefore you can't directly compare airspeed unless it's derived from flight test and expressed as calibrated airspeed.
No two airplanes will have an identical IAS (unless it's pure coincidence) for the same condition at the same gross weight, even when they are the same type (e.g., RV-10 and RV-10).
2. Maximum range glide occurs at an L/Dmax condition in still air. L/Dmax is not related to stall speed aerodynamically, but the AOA for L/Dmax is engineered into the airplane, and AOA controls airspeed, so the very first step is to flight test to determine what an L/Dmax conditions either in terms of calibrated airspeed. Either the EAA test cards or
AC 89-90C are a good place to start. You may also want to google
"bootstrap flight test technique". The latter is an interesting approach, but is a bit more complicated with a controllable prop like you have on your RV-10.
3. Maximum endurance glide occurs at a minimum power condition. This condition is aerodynamically related to L/Dmax. For velocity, Vmin power = V L/Dmax * .76 and in terms of AOA its AOAmin power = AOA L/Dmax * 1.73. That math is discussed in this short "how to" article:
Some Comments on Angle of Attack System Calibration.
4. As pointed out, glide
speed needs to be adjusted for actual wind conditions. To do this correctly, a computer is required. It's practical to apply a WAG adjustment to the Mark I eyeball assessment, but ultimately the only way to work the physics is with some digital help. Some avionics provide this capability. In this video, I'm testing a phone-based application that does the glide physics for me and provides guidance to high key (a known energy state, that is to say altitude and airspeed, over the the TDZ on the intended runway). From this position, a simple 360 degree descending spiral is flown to touchdown. Half way through the turn, the airplane is at a normal power off base position, called "low key." From low key to touchdown, it is 95% Mark I eyeball, but any "negative energy state" (insufficient altitude/airspeed combination) to reach the runway is detected by the computer and conveyed to the pilot graphically and aurally. In the test, you'll hear me use the term "on speed" which is the AOA associated with minimum power required/minimum sink glide. When the engine quits I only fly a single AOA/airspeed and let the computer handle the heavy lifting. It knows my glide ratio and planned bank angle for maneuvering, and since I'm flying an AOA, gross weight is automatically compensated for. I'm also applying drag (in this case Flaps 40) to compensate for residual thrust produced by the fixed pitch propeller at IDLE power, since glide angle at IDLE power is not the same and glide angle engine OFF. That's discussed in this
thread if you are interested in more information. Use of a single glide parameter (in this case min sink/max endurance) is purely technique that reduces pilot workload at the expense of some glide performance. You could just as easily fly an L/Dmax condition to high key and then slow to min sink for the final portion of the dead stick. Although not an aerodynamically bullet proof statement of fact, 1.3 Vs for current gross weight is generally going to be pretty close to max endurance/min sink if you don't have AOA. A good glider pilot can likely easily transition between L/Dmax and min sink just looking out the window. I'm not a good glider pilot
, but I've got an iPhone and an AOA tone that works like a variometer:
The bottom line is that the only way to determine best glide speed for your specific airplane is by flight test. Such is the nature of experimental aviation, even though we don't think of ourselves as such, we are all experimental test pilots from time to time. Pretty cool. If your GPS/moving map display has some sort of glide envelope prediction, use it to the fullest extent and practice with it from time to time.
Fly safe,
Vac
