Mine just dumps straight onto the cowling making a mess. I’ve been meaning to make a tube of some sort so it dumps past the cowl. Any pictures from 8A builders for ideas? The 8 is easy because you don’t have the nose gear in the way.
Carl where did you get that elbow fitting? Or what type is it? I’m assuming the same sniffle I have will screw on it?Add a 90 degree fitting, then the sniffle valve. Some tubing to exit the back of the cowl. Run the tubing to clear the nose gear.
The photo shows two tubes. One for the sniffle valve the other for the fuel pump diaphragm leak tube.
I’m not sure. It might have been at the aviation department at Lowes. Here is an ACS one that may work. The thread size is the same for the sump as the sniffle valve.Carl where did you get that elbow fitting? Or what type is it? I’m assuming the same sniffle I have will screw on it?
I used a straight sniffle valve and connected a 90 degree rubber spark plug boot as the elbow fitting (readily available), then attached an appropriate length of aluminum tubing.Carl where did you get that elbow fitting? Or what type is it? I’m assuming the same sniffle I have will screw on it?
