This might help you decide: https://www.vansaircraft.com/2020/02/three-blade-propeller-for-the-rv-12-rv-12is-available/Getting ready to order 12iS engine. Has option to order 2/3 bladed prop. Not sure which to order. Any suggestions on which and are there any pros/cons.
There's maybe 2 or 3 (dozen) threads about 3 blade props on nosewheel RVs.Does anyone have any problems removing the lower cowling with a 3 bladed prop vs 2 bladed
Rob, Is this the Catto prop that people are talking about that is made of a composite material?There's maybe 2 or 3 (dozen) threads about 3 blade props on nosewheel RVs.
TL/DR: It's a little more difficult to de-cowl a nosewheel RV with a 3 blade prop.
My opinion? It's worth the effort. Smoother, better looking, better looking, and smoother.
Basis? I had a 2 blade warnake and now have a 3-blade Catto.
yes sir, but regardless of vendor or material the de-cowling takes more "attention" for a 3-blade on an A model.Rob, Is this the Catto prop that people are talking about that is made of a composite material?
3 blade will feel a little smoother but the added difficulty in de-cowling is a consideration. Some of us de-cowl just to let the engine get vitamin d from the sunGetting ready to order 12iS engine. Has option to order 2/3 bladed prop. Not sure which to order. Any suggestions on which and are there any pros/cons.
Which one did you go with? I went with the 2-blade. I thought the wider blades looked better than the narrow blades on the 3-blade. I also thought it would be easier to remove the cowl with the two-blade.For most it's a personal decision. If you have the chance, try to look at both in person. I was convinced I wanted to go with one option, until I saw them both in person at KOSH. I changed my mind and ended up ordering the other one.
I went with the 2 blade prop. In general, I usually prefer the look of 3 bladed props. However, seeing the skinnier blades in person, made me think of props used on ultralights or paramotors. There's nothing wrong with that. I just prefer the beefier appearance of the 2 blade.Which one did you go with? I went with the 2-blade. I thought the wider blades looked better than the narrow blades on the 3-blade. I also thought it would be easier to remove the cowl with the two-blade.
- For efficiency at cruise, simplicity, and cost-effectiveness, a two-blade propeller is recommended, particularly for aircraft primarily used for long-distance cruising at lower altitudes.
- For better climb performance, reduced noise, and operations on shorter or rougher runways, a three-blade propeller is preferable, especially in more challenging operating environments.
Rob,I used to subscribe to these rules too.. back when I was building and decision time came. However, now that I've done a few very long cross-countries (NJ to Florida 3x; NJ to OSH 3x).. I can say that the 2-bladed noise and vibration does wear on you.. so if your mission is LONG xctry, you still might want to consider the 3-bladed prop for these reasons.
My observations and opinion are based on 1997 RV6 with O-320 engine. Three propellers flown on this plane. Two blade wood, two blade metal, and three blade GA Sensenich. All three balanced well below recommended IPS. Both 2-blade propellers were very smooth in flight. The 3-blade in not as smooth and "feels" buzzier in flight. All three result in virtually same max speed at 8500'. The 3-blade seems to climb a little better than either 2-blade. The 3-blade has a steeper power off descent angle and needs a little power added for soft landing. My observation is that the performance of these three propellers on my RV6 are so similar that appearance and cost should be your decision inputs.Getting ready to order 12iS engine. Has option to order 2/3 bladed prop. Not sure which to order. Any suggestions on which and are there any pros/cons.
amckeen,My observations and opinion are based on 1997 RV6 with O-320 engine. Three propellers flown on this plane. Two blade wood, two blade metal, and three blade GA Sensenich. All three balanced well below recommended IPS. Both 2-blade propellers were very smooth in flight. The 3-blade in not as smooth and "feels" buzzier in flight. All three result in virtually same max speed at 8500'. The 3-blade seems to climb a little better than either 2-blade. The 3-blade has a steeper power off descent angle and needs a little power added for soft landing. My observation is that the performance of these three propellers on my RV6 are so similar that appearance and cost should be your decision inputs.
Rob,
I have come to the conclusion that after the build (ELSA),I will look into the 3 bladed props that are available.
Rob,Catto was developing a ground-adjustable 3-blade prop for the RV-12.. I think he's still finishing the design though.
I never understood the choice being made for appearance. If you're tail heavy get a Three blade. If you're concerned with ground clearance get a Three blade. Otherwise get a two blade.Getting ready to order 12iS engine. Has option to order 2/3 bladed prop. Not sure which to order. Any suggestions on which and are there any pros/cons.
I believe the 3 blade gives you .55” more ground clearance, not that significant.If you're concerned with ground clearance get a Three blade.
This is true only if all other things are equal. That is seldom the case!Two blades is more efficient than three.
Yes due to blade to blade turbulenceTwo blades is more efficient than three.
Update, Sensenich performed a static balance check of my 3 blade GA propeller. It is now very smooth through the whole RPM operating range. It's performance is excellent, better than my wood or metal propellers. Highly recommended.My observations and opinion are based on 1997 RV6 with O-320 engine. Three propellers flown on this plane. Two blade wood, two blade metal, and three blade GA Sensenich. All three balanced well below recommended IPS. Both 2-blade propellers were very smooth in flight. The 3-blade in not as smooth and "feels" buzzier in flight. All three result in virtually same max speed at 8500'. The 3-blade seems to climb a little better than either 2-blade. The 3-blade has a steeper power off descent angle and needs a little power added for soft landing. My observation is that the performance of these three propellers on my RV6 are so similar that appearance and cost should be your decision inputs.
