Comes on with the nav lights??By the way, I don't fly at night but how do you turn on that eyeball light on the roll bar? I have the Skyview Classic. No interior lighting switches. Just curious!
I’ll let you know.By the way, I don't fly at night but how do you turn on that eyeball light on the roll bar? I have the Skyview Classic. No interior lighting switches. Just curious!
The previous owner installed that eyesore. It will be gone post haste.I have to say that is the sloppiest mounted camera mount I have ever seen. Im sure you can pop it off and figure out a much better way to do it. I have a 9 but it looks like the same center piece from the roll bar to the baggage area. I put a camera mount on it because it was easy with just a flat piece of aluminum bent on a 90 on each side. Then I mounted an adjustable mount on that and it works great for an interior camera. I will take a picture of the mount next time I am at the airport. If it ever stops snowing out here I may be able to get a flight in!!
Sam Buchanan below correct answer. Comes on with Nav or Nav/strobe switched on.By the way, I don't fly at night but how do you turn on that eyeball light on the roll bar? I have the Skyview Classic. No interior lighting switches. Just curious!
Looks like a VOR/ILS antenna.What are the other two rods coming from the top of the baggage bulkhead at an angle in each direction?
CorrectLooks like a VOR/ILS antenna.
