discovered today, ~350 hours TT RV-6. crack in baffle flange at nutplate, and also a cracked doubler for the baffle cyclinder attachment? Planning to beef up affected area, any advice appreciated for a second owner/non builder.
photos.app.goo.gl
This worksOthers have used a brace to the engine spine.
The #4 bulkhead was changed to 6061 or 5052 in the last 8 years or so...I should have added to my original post that my 7 did the same thing at around 200h back in 2011.
Here’s the replacement: 1/8 angle plus an extra tie piece. I also installed a diagonal brace from the forward edge of the #4 cylinder to the inboard edge of the oil cooler mount.
My memory is stretching for this but I also seem to remember that that particular baffle piece was or should have been 6061 not 2024.
I mount the oil coolers on the firewall with an air duct going to it isolated from the engine movement, no cracksThe #4 bulkhead was changed to 6061 or 5052 in the last 8 years or so...
So do I...I mount the oil coolers on the firewall with an air duct going to it isolated from the engine movement, no cracks
So do I...crossing my fingers that the repair lasts.
Good luck indeed. I replaced my (cracked) original bent baffle angle + doubler with a .063 angle which lasted a couple of years. Then that cracked plus the outboard cooler flange. I mounted the new and larger cooler remotely and haven't had a problem since (15 years ago?).additional .032 angle to stiffen the #4 baffle, crossing my fingers that the repair lasts........
See post #7. There is a reason I mounted it to a solid piece of STEEL! No problems since original installation.Good luck indeed. I replaced my (cracked) original bent baffle angle + doubler with a .063 angle which lasted a couple of years. Then that cracked plus the outboard cooler flange. I mounted the new and larger cooler remotely and haven't had a problem since (15 years ago?).
Bruce,Lots of baffle photos on my build log site.
I've now got 1250 hours and no cracks with my installation. I did add the aluminum angle piece along that vertex, and most importantly a brace between the cylinder head and the oil cooler mounting bolt.
This prevents the relative motion along that edge of the #4 baffle. If you can prevent the movement, no cracks will form.
Indeed - it seems Van's has learned this on the newer models. If you are still building, I'd recommend copying the RV-14 or another model with remote mounted oil cooler. Mine's on the baffle, and I think that was a mistake.Attaching an oil cooler to an engine baffle can hardly be considered good practice, as has been demonstrated once more here.
I bought the screw at Marshall's Industrial Hardware in San Diego. Just about any Ace or True Value store should have coarse thread 1/4" hardware in various lengths.Bruce,
You wouldn't happen to recall where you found the screw long enough to go through the #4 cyl, rocker cover and brace? I looked all over and could only find one long enough for the threads to barely clear the nut.
Chalk up another cracked baffle on an RV-8. Same location as the other posters. Had same oil cooler setup on an RV-6 but with plenum cover, had no problems. Van's needs to fix this. 4+ inch crack was discovered yesterday after 140 flight hours on new baffle. Thanks to those who posted solutions.I bought the screw at Marshall's Industrial Hardware in San Diego. Just about any Ace or True Value store should have coarse thread 1/4" hardware in various lengths.
Marshall's - best all round hardware store (not big box) ever!!I bought the screw at Marshall's Industrial Hardware in San Diego. Just about any Ace or True Value store should have coarse thread 1/4" hardware in various lengths.
Cut a piece of 1/4x20 all thread to the length you want. Then just use washers and a nut on the rocker cover end so you can take the cover off without disturbing the brace end.Bruce,
This is what I did on my 7 when it cracked after 100 ish hours and what I did on my 8 so I wouldn't have any BS with it. Sorry for the lousy pic but all I had. You can see the one angle p-clamped to the mount. The other is behind and 2 glass transitions connected with 4" scat.
I certainly don't mind. I only wish I was tech savvy enough to do that!I think the remote oil cooler is the best solution, and I will (maybe) change to that. I zoomed in your picture and used a web AI to sharpen it - hope you don't mind.
It looks like your engine mount puts the engine farther fwd than mine (O320, rv-6) would be hard to do something similar with the space available
Just showing an option/concept. Remote is remote as long as the air can get out. Placement will a vary on most any installation; engineer mount, firewall, whatever. Follow the King’s advice. Make yours the same, ‘cept different.It looks like your engine mount puts the engine farther fwd than mine (O320, rv-6) would be hard to do something similar with the space available
Thanks John. 1100 hrs on that oil cooler install. No issues so far. My pics went away when Expercraft went belly up. Still have them but the chore to restore to VAF posts is too much. Take care.I like what rzbill did. His photos got deleted but I had saved them.
The j channel is a beam to stop the oil cooler flapping back and forth.
Airplane RV oil cooler support rzbill VAF https://vansairforce.net/threads/oil-cooler-bracket-separated.73707/#post-556594 · Mar 19, 2011 – Dec 17, 2025 📸
Shared album · Tap to view!photos.app.goo.gl
.Oil Cooler Bracket Separated
What would be the best way to repair this. The bracket that attaches the oil cooler has separated. Actually the baffles on both sides were cracked in a couple of places because they were joined together at both cylinder heads, and there was no expansion joint. Any ideas on a sturdier way to...vansairforce.net
Any suggestions on how to fab the tubular brace? Are these available for purchase and/or do users just fan/bend one on their own? What stock do inputchase? Thanks for any help.Lots of discussion about this problem on the forum - the solutions are either:
- replace those parts as-is and accept future cracks
- beef up everything with stronger angle and bracing between the #4 cylinder and the baffle
- move the oil cooler off the baffle to reduce the weight carried by the baffle
- some combination of the above
Based on later models of RV, it seems the factory recommends #3 - move the oil cooler off the baffle.
Did something very similar at initial build. 1500 hours with no cracking.I should have added to my original post that my 7 did the same thing at around 200h back in 2011.
Did a similar thing early-on but attached to the angle stock stiffener on the baffle instead of the cylinder--same results with no cracks! Seems that keeping this corner from cycling with engine vibration prevents cracks in that corner of the baffle. I made my brace from a section of angle-stock but same idea.Lots of baffle photos on my build log site.
