I am considering using the MZ-30 Generator on my Aux bus and I'm trying to figure out what I need to change in the Z-14 wiring diagram to make it function.
Differences:
MX-30 comes with it's own external regulator- Minimum installation calls for an enable switch. Can I work this wiring into the Aux Master Switch so I have 1 switch instead of 2?
Would the same S700-2-10 switch be used? Or should I keep it separate to have a means of isolating it? How would the Aux Master Switch be wired?
I am a novice at this! Just started working on wiring plan. Be kind!
Dan
Differences:
Dan
