It’s winter in upstate so I’m trying to get through a bunch on maintenance items on my 6.
I’m just through the first 100 hours on a vans rv-6.
I was not the builder.
It looks like the engine has sagged down a little. I’ve reviewed several writeups on inserting an additional washer on the lower mount but what I’m not clear on is whether I have to remove the upper mounting bolts to raise the engine enough to pull the lower bolts and insert the washer.
It seems like I would attach the engine hoist, remove the lower bolts, raise engine slightly, insert washer and install the lower bolts.
Is that basically it? Is there a specific writeup I should refer to that’s best?
