I have asked plenty of questions and it's time to cut. Local metal laser shop is cutting it, about $150. Hold my hand, ha ha. I am pretty much locked in to final design give or take a few details. But last chance to "change my mind". Take a look, any gotchas you experienced. suggestions.
Q: Laser cut question. Cutting corner radius of rectangular shapes, I assume the shop software is set to some min, but I will confirm. Do I have to model in corner fillets?
I have a panel sized piece of plexi as a test, but the metal cutting laser shop can't do it. I could cut it out by hand, but...
I did use ridged foam board and mounted all the items. In an attempt to make the "center stack" dead center it made is CROWDED and NO METAL. I used ridged foam board. I used wood supports. With the foam board face up I dropped everything in. It looked bad and did not like the skinny strips of metal. I spread things out and happy giving up on symmetry.
LOGIC? (Goal cost effective ($13000) IFR glass panel. I did it combo of buying used, sales, and bought most items, before prices went through the roof.)
GRT HORZ 10.1 EFIS, Safefly GPS, Digital Magnetometer and dual servo auto pilot. Great value and got an airshow discount.
GRT EIS (engine monitor) mounted in panel is staying. You can hide the EIS 4000, but for FF reset you have to hunt for it I believe. (EDIT See bottom of Post #22, ** note, not quite correct but there are factors in remote mounting the EIS with a display to consider.) Ask GRT. Main reason is BACK UP if the EFIS goes bye bye. It's staying. I bought this long ago for my project that has taken a little longer than expected (little cough couch).
ICOM A220, bought used. I wanted a stand alone panel mounted radio. It's a me thing. Down side it is deep and goes through second Fwd bulkhead. Remote COM, controlled with GRT Horz 10.1 EFIS is a slick option, I could still do it. It takes no hole in panel. However lose EFIS you lose control of remote COM. It may still work last Freq. Panel mounted ICOM advantages outweighs the remote. The GRT EFIS does shoot Freq into ICOM standby which is nice.
My Trig TT22 transponder is remote and should keep working with no EFIS. GPS still provides position. However air-data and ADS-B out might be lost? Can't change squawk code or ident. Not an airliner with 2 transponders. Shopped around got about $300 savings
Garmin G5 is totally separate with onboard backup battery. I bought a used one with all the goodies used, it is the certified model. Saved $1000. No difference in Cert and Exp G5's but they did go through STC process to get it past FAA, what ever that is worth. With AHRS, magnetometer it's redundant to the GRT EFIS. The ARINC 429 module lets the GPS175 talk to the G5 for redundant RNAV LPV approach ability.
ADS-B is a Stratux I had and bought a while back. I repurposed. Nice thing about GRT, besides nice folks, is they work with a variety of 3rd party devices. It helps give you flexibility and saves some money. ELT? Last last thing to buy and waiting to the last last minute. Likely going ARTEX.
Cost total, about $13,000, with the caveat things bought awhile ago. I bought some used items (G5, ICOM). Some things like mil spec toggle switches and circuit breakers I have had for 20 yrs way before this project was started. I did not include those. If you bought new today, no used, with current prices it would be $16,500 to $18,000? This is an *IFR panel, 2x autopilot, dual AHRS, GPS175 IFR GPS, Full GRT ETIS and EIS, ADS-B IN & OUT and ENGINE MONITOR w/ FF. *IFR Light - no VOR/LOC/GS and one COM with standby Freq monitoring). * I did not include cost of iPad mini running a EFB (not Foreflight), which is a nice backup.
Last chance to change my mind? Twist my arm. Time to commit. but hold my hand. Ha ha. (I do want to avoid wasting a panel, a spare. Long story but bought a 2nd stock panel from guy who did not need it. )
Yes I know the CAD does not match eyeballed HangerTalk doodle, but bare with me, still playing with switchology, dimmer controls for 1 or 2.
[Note for those in planning stage, be aware the standard panel only has 10.9" height from top center of panel to start of bottom flange radius. Van's DXF file is the flat pattern that shows that extra inch for the flange. The center hole is offset about 0.35" to right. Last depending on slider or tip up structure is in the way. My RV-7 slider has stiffener in three places plus the side longerons that have to be considered.)
Thanks for INPUT!!
PS - thinking of a keyed Mag switch, with start. I have P-Mags. One Mag switch saves two toggles and one push buttons. Key would be theft prevention? Well barely. There are ways to disable the plane for thief protection, prop locks etc.
Thanks for INPUT!!
