howardtlcc
Our engine has an unused stud on the left side, front of the engine that will prevent the baffle bracket from attaching. Per the plans it attaches via a screw to the empty hole. I guess there are two options, remove the stud (which will probably require a lot of heat to break the red loctite and ruin the paint) or drill a hole in the bracket and attach a nut (if there is room).
Anyone else encounter this?
