With a dual 10.3" G3X display, it seems there is precious little room under the displays for switches as the bottom of the panel frame gets in the way. From this standpoint, the Honeywell AM34 switches seem to be the most popular rocker switches and will fit in this space (require 1.14" x 0.75" cutout). However, these are very expensive and perhaps not the most attractive switches.
I'm curious what other switches builders have used? Had the panel frame openings been 1/2" taller, then the much more common 1.45" x 0.83" opening would be possible and many more rocker switches would have become an option (eg, Carling Contura).
Has anyone cut the bottom of the panel frame off to accommodate a slightly taller panel and permit alternative switches? Would this present any issues if using a 0.080" thick panel and perhaps bending the bottom edge to further stiffen it?
I know toggle switches would fit in this space too, but those look even less attractive than the AML34 rockers.
