Piper J3
My friend has 500TT on his RV-12 and is experiencing engine vibration when he throttles back from cruise power setting of 5500 RPM. The engine runs smoothly during climb and at 5500 RPM in level cruise. Ignition check at 4000 is always good. Ignition check in the air is also good. When power is reduced for a decent the vibration starts at ~5200 RPM and vibration continues as engine is slowed further. When powering back up the engine runs smoothly again.
We have contacted Lockwood Aviation and they say the gearbox drive dogs are spalled and cause this problem. AreoShell Sport Plus oil has been used since new. There are virtually no metal shavings on the magnetic gearbox plug.
For comparison… my RV-12 with 950TT on early SN 912ULS does not have this vibration. Gearbox has never been overhauled. I use Mobil 1 Racing 4T 10W-40 full-synthetic oil exclusively.
For those that have had gearbox rebuilt… I’m interested in knowing what symptoms justified rebuilding the gearbox and if condition was solved with the rebuild.
Thanks in advance…
Thanks in advance…
