Mark Basel
I'm New Here
Hello, TIA I’m working on my -8 wing wiring/routing. I’m Using The recommended size of 5/8” holes from the bellcrank area to the wingtip/wing root ribs by opening up the tooling holes. I am debating using conduit and or just the snap in bushings. Has Anyone experienced issues with just the snap in bushing through the wing? I’m concerned about the wires getting beat up from vibration and just moving around unsecured between the ribs. With any conduit however I’m losing space for wires to travel through as I will be using using Flyleds. If anyone is using just the bushings, are you securing the wires through the wing as well as at the end ribs of the wing.? What are you using? waxed string, zip ties or something else?
Mark
Mark
