Hello all
I noticed a while back that my engine is offset slightly to the left, relative to the cowl. This dynafocal mount is not the original mount. It was replaced a few years ago following a mishap. I am wondering if anyone has removed their engine and mount, replaced the mount and then found a discrepancy with cowling/spinner alignment. I had noticed earlier this year that the innermost nutplate was very close to the ring gear whereas on the right side, there was good clearance, so, I do believe the engine is to the left slightly. The builder is no longer with us so I cannot ask him about the original installation. I consulted with Van's and they felt that, after confirming that all engine mounts and washers are in place correctly, shimming under the mount at the firewall would be acceptable. I was wondering if anyone else has had to deal with a similar issue? I know there can be some variation between mounts, but it seems odd that it can be that much.....
Any suggestions/input?
Having a whopping 6 hours and 32 landings in my first flying RV, I am loving it.
