Long story. I needed to pull my baffle for a nagging leak that didn’t get fixed the first time drilling holes in the baffle to seal from inside. The original proseal became very gummy. Possibly a bad mix.
Now that I’ve drilled out all the rivets I noticed the counter sinks sit a little deep. I’m also able to place a -4 rivet in 95% of the holes on the skin to baffle rivet line.
Should I use the AD3 (3/32) or cut a thousandth into the counter sink to place AD4 (1/8) rivets? Is the .032 skin thickness an issue for that size countersink?
You can see two AD4 and two AD3 rivets in a row. As you can tell the 4s sit proud and the 3s sit low. I’m mainly concerned with the larger hole which I think happened during the original riveting.
I did the proper drill out procedure snapping each rivet head not to make the hole bigger.
