What I have done after changing out the oil system hoses is to remove the spark plugs and motoring the engine until I see oil pressure for a few seconds, yes I do know that doing this no oil is being returned to the tank because you need piston ring blow by that's why you don't do it for an extended period. I then install plugs, burp the tank then start the engine for leak check keeping an eye on the oil pressure for any fluctuations. If I remember correctly Rotax wants you to run the engine @ 3500rpm to purge the lifters. Done this same routine after hanging a new engine on a SeaRay with a Rotax 912ULS....BTW I have close to 600 hours on my engine and have never had anything more than fuzz on my chip detector.
