A number of folks here are arguing against gaining extra margin (even when there is essentially no trade-off or sacrifice of anything else) on the basis that it is a pilot problem, not an airframe problem.
The exact same argument is often made about the original 6A/7A/8A/9A nose gear. And also in that case, an improved alternative now exists.
Here is an anecdote that illustrates the benefit of having 'more margin':
I believe this happened in the mid 1980s. A 4-engine transport was crossing the pacific at very high altitude (41,000 ft IIRC) with a full load of passengers. One engine failed. The result (for whatever reason) was that the airplane stalled, rolled and pitched down. The recovery took something like 30,000 ft of altitude, probably exceeded V_d (The equivalent of V_ne for high-mach no. airplanes) and reached a load factor of something like 5.2 g's.
For a Part 25 transport like this, N_lim is 2.5 g's, and the ultimate safety factor is 1.5, so during certification, the airplane has been shown to withstand 3.75 g's. At that load, it is allowed to yield (bend) but must not fail. There is no expectation that the airframe should survive loads greater than 3.75 g's.
This airplane, built by Brand X, did not fail at 5.2 g's. It landed safely at San Francisco International airport. I got to see the airplane. Both wings were bent slightly, one more than the other, but you could visually see the abnormally high dihedral. The wing-body fairing area adjacent to the wing leading edge, where the air conditioning systems are installed, were bent/buckled inward (from the large forward chord force during the pull-out). The horizontal tail was visibly bent downward. Fuselage skin around the horizontal tail attachment was wrinkled. The airplane was later repaired and returned to service!
5.2 g's.
There are a whole lot of people that are really grateful that Brand X built in those kinds of margins into their designs. I would speculate, based on some other incidents, that had that been a Brand Y airplane, it would not have survived the flight.
How much margin is a good amount of margin? It is never infinite. Something is always eventually going to break. Design margins are often based on statistical exposure to exceedences traded off against ability to perform the intended mission. (that's where the 2.5 g, 3.8g, 4.4 g, 5.3g, 6g load factors come from for various categories of aircraft, and where the safety factor of 1.5 comes from). Since airplanes really don't crash very often, these always have been based on very small sample sizes, and always based on incomplete information. Yet we follow what evidence we have, even if not conclusive. Here you have similar population sizes of similar aircraft, with similar pilot demographics, and a seemingly minor difference in construction that correlates to some tragedies for one of the designs and none for the others.
I don't know if it ever makes sense to leave margin on the table if it doesn't cost anything.
