Trying to figure out what all I need wiring for in each wing, here's what I have so far:
Electrical/pneumatic:
• L/R - Wiring for wingtips (landing, taxi, position, strobe, area) I am installing the integrated AeroLED wingtips with all the lights in the tips
o 3 strands of AWG shielded wires
o Use Vans Conduit
• L - Wiring for pitot tube heating/controller
o Use center hole with grommets
o Mount to nearest wing rib
• L - tubing for Pitot/AOA sensor
o Use top and bottom holes with grommets
• L - Wiring for OAT sensor
o Left wing inboard-most access plate?
• R - wiring for autopilot servo
o Use Vans Conduit with opening
• ADAHRS??
• Magnetometer??
The last two are the ones I'm unsure of as to where those typically get mounted, in the wings themselves or out on the tips inside the wingtips?? Looks like I'm going with Dynon for the avionics.
o Use Vans Conduit
• ADAHRS??
• Magnetometer??
