It depends on a few things. Are you going to be doing this yourself (assuming you're either an A&P or LSRM)? How many hours on the aircraft and engine?First annual for my 2023 SLSA RV12is is coming up. Any advice on things or parts to order ahead of time?
An A&P will be doing it. We have ordered the SB-00088 kit. I have not ordered the replacement hose so I will put that on my list. The aircraft has 135 hours on it.It depends on a few things. Are you going to be doing this yourself (assuming you're either an A&P or LSRM)? How many hours on the aircraft and engine?
A very partial initial list:
* Oil change materials - 3+ liters oil, Rotax oil filter, crush washer
* Rotax fuel filter (likely provided with the aircraft)
* Not required, but it'd be a good time to complete SB-00088, so the kit for that, plus some replacement hoses (just in case)
There is also a difference between what is required for the annual condition inspection and what is required for the annual maintenance items.
I recently completed this inspection and maintenance on my 2023 SLSA RV12iS (I do have an LSRM certificate)
With 135 hours, the Rotax 100 hour service should have already been done, which includes oil change, compression checks, downloading data from ECU using the oh so economical (sarcasm) BUDS dongle and replacement of that fuel filter. Check the Rotax 912iS Sport Line Maintenance Manual (MML) section 05-20 for full schedule. Thats available from flyrotax.com I highly recommend ensuring the A&P has Rotax training. They are great engines, but not the same as Lycoming or Continentals.An A&P will be doing it. We have ordered the SB-00088 kit. I have not ordered the replacement hose so I will put that on my list. The aircraft has 135 hours on it.
This. I would advise them to download the latest Rotax Maintenance Manuals and follow them exactly. The first time I let an A&P touch my engine who wasn’t Rotax-certified, they started media-blasting the spark plugs after they were removed.I hope your A&P has some training on the Rotax 912 because there are some key differences with traditional engines. For example, on traditional engine spark plugs you put some anti seize on the threads but on the Rotax you use heat paste.
WHAT IS SB-00088? Not on the Van's SB website!!It depends on a few things. Are you going to be doing this yourself (assuming you're either an A&P or LSRM)? How many hours on the aircraft and engine?
I believe it’s still there. RV12iS (Coolant) Radiator Attachment Modification.WHAT IS SB-00088? Not on the Van's SB website!!
It is an "optional" service bulletin that, as someone that has experienced the radiator failure, I wouldn't recommend performing. My plan is to wait until next failure then replace radiator with the new design. Given that the failure seems to be the result of external forces causing the bottom row of fins to pull away from the frame I believe the forces involved in cutting the radiator frame could instigate the same issue prematurely.I believe it’s still there. RV12iS (Coolant) Radiator Attachment Modification.
This is a very interesting point. Thanks for sharing. I would really be curious what the community thinks on this point. Do the radiator fix or wait?It is an "optional" service bulletin that, as someone that has experienced the radiator failure, I wouldn't recommend performing. My plan is to wait until next failure then replace radiator with the new design. Given that the failure seems to be the result of external forces causing the bottom row of fins to pull away from the frame I believe the forces involved in cutting the radiator frame could instigate the same issue prematurely.
Better yet this........#2 Phillips Screwdriver... I always felt that the perfect retirement gift for A&P mechanic would be a gold-plated #2 Phillips Screwdriver
I agree with Amadeus, skip the “fix”. Replace Radiator or wait? I think it depends on your missions and risk tolerance. I’m fairly risk-averse with my $100k (pick a number) aircraft and $40k engine. And I hate walking home <grin>.This is a very interesting point. Thanks for sharing. I would really be curious what the community thinks on this point. Do the radiator fix or wait?
The best Philips screwdriver isn't even a Philips.. it’s a JIS or Japanese Industrial Standard. It fits Philips better than any Philips screw driver. Go to Amazon and look for the Vessel brand JIS with the light aqua color.#2 Phillips Screwdriver... I always felt that the perfect retirement gift for A&P mechanic would be a gold-plated #2 Phillips Screwdriver
