You can buy the wheel hub with races and bearings installed for about $170. This would total to less than paying a machinist to press out the races for you to DIY the bearings. And it would be done right. Call Matco.Every revolution of my RV-12's left main gear emits a clunking noise. I removed he brake caliper completely and rolling makes same clunking noise. I assume one or both bearings are bad. Do I need to replace the race also? I don't know how to remove it. (I didn't build the plane.)
Thanks for advice, Tony.Your can buy the wheel hub with races and bearings installed for about $170. This would total to less than paying a machinist to press out the races for you to DIY the bearings. And it would be done right. Call Matco.
