RAM Ball Mount Location
VF84Sluggo
I'd like to move that Ram ball mount from down low up to that more user-friendly higher locatin, as shown in the pic. But, I'm hesitant to drill holes in that triangular webbing. I worry about compromising structural strength if I do that. Are my concerns unnecessary?
Thanks in advance,
Randy
Here’s how I mounted mine. The four 8-32 screws serve as a pilot to keep it centered in the large center hole,with an 1/8” round steel ring/washer slightly larger than the hole with threads taped for the 8-32 screws. With offset of the ram mount it rotates in the large lightning hole giving great adjustability.
I used the double stick pad attachment and stuck it to the side of the inside glare shield/exterior body right above and forward of that triangle. It works great and is well out of the way but useful too.
Ok, because I found .02 inches (very thin) and .04 inches (still sounds thin to me)...and sorry, I not a metric guy, can't relate much to millimeters.
I am using RAM's magnetic mount in that basic area in my -9A (on the left side). Seems to work fine holding my iPad Mini and stays in place, unless I bump it with my knee getting into the plane. So far, it stays put in turbulence. I've been using it this way for a tad over a year.
It looks the same as your current mount, but magnetic.
I just mounted mine like this. The nuts were a bit tricky to hold down but this works great. No screw holes. Not a permanent mount. Nice idea, Thanks!
I ended up using the RAM mount that has a diamond-shaped base, 2 screw holes. Fabricated a matching diamond-shaped plate out of 1/8” aluminum, tapped matching #8 screw holes in it.
Using some of that super-sticky tape mentioned earlier on the RAM mount and the fabricated plate (to hold these two items in place and prevent sliding later with iPad mini mounted) I sandwiched angle structure in between them. The holes for the screws are in the open circular cutouts of the airplane angle structure.
I then added a tad of red Loctite and snugged down the #8 screws to hold everything in place. No drilling into the airplane structure was needed. The mount is nice and secure, much better location for the iPad mini.
