Ok, looking at this tape. When you say thin, how thin?Get some thin Scotch VHB tape and stick it where ever. Tape is amazingly strong, but you can always remove it.
It comes in various widths and thicknesses. The tape is double sided and the type I have used is gray foam that is about a millimeter thick.Ok, looking at this tape. When you say thin, how thin?
Thx
1 mm is 0.04 inchOk, because I found .02 inches (very thin) and .04 inches (still sounds thin to me)...and sorry, I not a metric guy, can't relate much to millimeters.
Definitely going to go with the tape plan, rather than drill holes.Get some thin Scotch VHB tape and stick it where ever. Tape is amazingly strong, but you can always remove it.
I just mounted mine like this. The nuts were a bit tricky to hold down but this works great. No screw holes. Not a permanent mount. Nice idea, Thanks!Here’s how I mounted mine. The four 8-32 screws serve as a pilot to keep it centered in the large center hole,with an 1/8” round steel ring/washer slightly larger than the hole with threads taped for the 8-32 screws. With offset of the ram mount it rotates in the large lightning hole giving great adjustability.
I don't like the idea of any kind of magnet in the cockpit area. The magnetic field could affect your heading.Didn't know RAM had a magnetic mount! I'll look into this, too. Thanks.
Yeah, I abandoned that magnetic idea.I don't like the idea of any kind of magnet in the cockpit area. The magnetic field could affect your heading.
