(what did you do with your RV this weekend?). Getting this weekend's thread started…
v/r,dr
v/r,dr
You are an inspiration!!(6) weeks,
(6,100) NM
(50) hrs tach time
NA romp flight
Taos mountain bike, Synergy Fundamentals, First Flight aerobatics, Hudson (NYC) no-one free-for-all, Canadian relatives, lotsa cool grass strips, friend’s lake visit, plus bi-annual.
Would’ve ventured longer, but wifey said, “It would be really nice if you’re back by July 4.” And, she’s Canadian….
Did PHX to MHV yesterday morning at 10.5k and the lowest OAT I saw was 67 degrees. Brutal!Trying high altitude flight 15.5K and 16.5K to beat the heat.
Brutal? My boys and I were at scout camp north of ATL by 120 SM last week where the low was 65 - overnight (only once). Let's not even discuss humidity....Did PHX to MHV yesterday morning at 10.5k and the lowest OAT I saw was 67 degrees. Brutal!
I think you missed the point that the 67 degrees was AT OVER TEN THOUSAND FEET cruise altitude! I landed in MHV and it was 105, headed for 112.Brutal? My boys and I were at scout camp north of ATL by 120 SM last week where the low was 65 - overnight (only once). Let's not even discuss humidity....
Perspective is everything. Thanks for the chuckle!
Mike
At 7k during climb, oil temp went to 185F. Had to reduce power to 65% to keep it from going higher. Chts were all ok thouI think you missed the point that the 67 degrees was AT OVER TEN THOUSAND FEET cruise altitude! I landed in MHV and it was 105, headed for 112.
Didn’t fly an RV this weekend but I did get my tail wheel endorsement in an awesome Super Cub while visiting my family in Bentonville, AR. It was a whole lot of fun. I can’t wait to find out how my RV-8 will compare on landings to the Super Cub.
Oh wow, small world. I flew every day 7/3 through 7/7, mostly in the pattern at KVBT.You're not gonna believe me, but depending on what day you were flying, I was also visiting family in Bentonville, whose house is in the approach path for KVBT, and I'd pull up flightradar24 every time a plane was overhead, and I definitely saw that yellow super cub. Small world.
Yep, completely missed it!I think you missed the point that the 67 degrees was AT OVER TEN THOUSAND FEET cruise altitude! I landed in MHV and it was 105, headed for 112.
JohnAt 7k during climb, oil temp went to 185F. Had to reduce power to 65% to keep it from going higher. Chts were all ok thou
At 15k + above inversion layer outside air temps were more reasonable at 45F
I was running at 130F for the longest time, but then added a 1” block off plate to cooler. This lowered my CHTs and raised the oil temp to 160ish. But my yellow starts at 186F and goes to red line. My manual says to keep oil above 140F. JMHOJohn
Not sure what your oil temp limits are but Lycoming recommends at least 180F. I’m happy to keep them between 180F and 200F. The limit if I recall correctly is 230
regards Peter
Sounds like your boys were were my boy was a week or so ago...Brutal? My boys and I were at scout camp north of ATL by 120 SM last week where the low was 65 - overnight (only once). Let's not even discuss humidity....
Mike
johnI was running at 130F for the longest time, but then added a 1” block off plate to cooler. This lowered my CHTs and raised the oil temp to 160ish. But my yellow starts at 186F and goes to red line. My manual says to keep oil above 140F. JMHO
Practice 90knot “slow flight”, alt hold 1,800’ and close in-short approaches in prep for my 1st trip to Oshkosh. The landings got fun after the first couple frustrations.
Saturday 6 July 2024 Flew from Mossel Bay to Springbok to inspect and sign out an annual inspection on an RV8. Light snow on some of the mountains. Landed in a howling crosswind. Then onwards to a friend’s farm gravel strip for coffee and then home. Flew over the SKA 2km telescope array on the second leg. A nice 770 nm hop. Last leg with a healthy 30 kt tailwind which meant a strong mountain wave over the Swartberg. RV Uber alles.Camp Rainy Mount in Clayton. Another was working at Woodruff in Blairsville. Good times! Y'all?Sounds like your boys were were my boy was a week or so ago...
