So, I still have a can of this from the 80s. An old timer at that time suggested I buy it and it will last me a life time.
Yep, devil spawn lube.
Actually, that quote is attributed to H. L. Menken.I believe it was PT Barnum that said, “No one ever went broke underestimating the intelligence of the American people.”
So for all of these years has this been the wrong stuff? Does this even have a place in aviation anymore?
My cupboard is staring to look like the shelves of an automotive store and is becoming more confusing on what does what. 565, 567, 56521, with PTFE etc. Anymore Im not even sure if we are talking about the same stuff or if there is dyslexia going on with the changes in the numbers and Im back googling to see whats what.
Not RTV.. too many people go to rtv for everything. It has it's place but doesn't stand up to fuel or oilNOT RTV
It is unfortunately also easy to underthink it. I believe there was a case of an RV-10 (?) that was lost due to the NPT fuel fittings being sealed with RTV. RTV is generally not fuel-safe, which lead to a gob of it being liberated, lodging in the fuel flow transducer and stopping the engine.
Yeah, I try to get one flat out of them. Most of the time its a guess...What are you going to torque those B nuts to? Most of the time it is tightenuff.
Putting pipe sealer on the AN threads will change the 'torque value". But some of use use the 'flats method' anyway, or the German version of Goodntite.You are correct, that is not the right place for sealant. I'm not sure if the presence of sealant will prevent the B nuts from torquing correctly. If it were me, I'd remove the sealant.
