DeltaHawk for RV-14
Craig,
Thanks for the updates on this and please keep them coming, great work you’re all doing there.
I’m new to homebuilding having just started my RV-10 tailcone, but not to product development. It’s one thing to develop great technology but another to be commercially successful with it. You can have the best solution for any given challenge, but if market conditions are against you it can be almost impossible to build a business around it. Until those conditions change or you find a better application. If engine manufacturers are able to utilize decades-old machinery to make proven engines at low cost but can sell them for high prices, that’s hard to compete with. Until fuel options change, for example. Disruption is hard, but it’s amazing when it happens. Before it happens, most people think it is impossible. When it does, most people say it was inevitable. It never was and it never is—it takes relentless developers to keep pushing and bridge the gap.
Kudos to you and the team and I wish you best of luck. By the time I get to my FWF kit, I look forward to having another engine option to choose from.
Craig,
I think the fuel options may end up being the market disruption needed (especially in California). 100UL vs 100LL cost and availability will be, in my opinion, a big factor in the success of this engine. Keeping my fingers crossed that they succeed!
Me too but I’ve been waiting the better part of two decades…
All,
A few more things to share. See below the CADs on what should be the final design and layout of the ducting as well as the cowl design. DeltaHawk is certainly letting function drive form as the performance of the package is paramount. However, I think they've done a great job maintaining the aesthetic of the RV14, while allowing for the distinct design elements that differentiate the DeltaHawk powered RV14 from one with a Lycoming. As beauty is in the eye of the beholder - let us know what you think. Incidentally, as folks will likely spot these, let me point out a few differences between the stock RV and the DH in regards to the FF:
> Yes, the cowling is longer. By about 3". As I posted earlier in this thread, its almost identicle to the cowling length on my current RV14. Hopefully this will give some perspective on how 'long' the nose will be. My 2-cents, it will not be very noticable, and likely only to those who are very familiar with the stock RV14. I'll post more detail on the exact structure of the cowling as we get it fitted in place.
> The nose cone/spinner are larger than the stock RV14. I cannot speak to this (aestheticly) as I have the stock ones on my current14. But, from looking at the CAD's, it appears it will look fine.
> There is an inlet on the lower cowl. This is similar to what I currently have on my 14, and also somewhat like is seen on a lot of RV7's. The shape of the DeltaHawk inlet is unique and will likely be the most noticable clue that to whats under the hood.
Fabrication is moving forward and, as I mentioned previously, DH will have the entire set-up (FF package with engine) mated to the fuselage to show at Air Venture this year before sending it on the Eugene for final assembly (of the airframe) and initial flight testing. The caveat here is that until static testing is completed, the design is still subject to modifications. Much work has been done to ensure everything plays well together - but, as builders are all too aware of, nothing quite duplicates the real world. That said, DeltaHawk's experience gained with the Cirrus and other installations is proving to be a great benefit to the RV14 project.
Finally, I will have something to share on the panel later this week.
Craig
Craig,
How will you make the transition from the cowl inlets to the duct? I’d guess neoprene sleeves like on the James cowl and plenum.
When you say the spinner is larger is that length, diameter or both? Like the RV-10 the 14 could use a larger diameter spinner. I’m using a 14” on the new RV-10 project.
Carl,
Re nose cone/spinner - A bit bigger all around. As for the cowling - as we get into the smaller details, the chances of something being modified increases until the final design is fitted. So I can’t speak to the transition yet. Nonetheless, DH should have all this worked out by the Air Venture and on display for all to see.
Craig
Hi Craig, thanks for sharing the pics of the updated cowl and ductwork. Overall it's looking pretty good but one thing that jumps out to me is the break in the plane between the forward upper fuselage skin and the top surface of the cowl where they meet at the firewall. On the original RV-14, Van's lofted the upper surface lines to flow nicely together in the same plane. This is one of those things that won't bother some folks, but people like me who are cursed with an eye for this sort of detail will notice the disparity immediately and it will be much more obvious on a completed airplane with glossy paint.
Looking back at the pics in your 4/18/24 post, I don't see any structure (engine, mount, etc) that is up high enough to prevent lowering the upper cowl surface to be in the same plane as the forward fuselage skin, so I hope DH will consider making that change to improve the aesthetics. The larger spinner will require the cowl 'fairing' area behind it to extend further aft before it blends/disappears into the upper surface, but IMO that would look better than how it is currently lofted.
Will DH be making a custom spinner or leaving that to prop manufacturers? For ideal aesthetics and aerodynamics, the lines of the spinner and cowl should match nicely...Van's has accomplished that by designing & providing both. Hoping there will be a matching carbon fiber spinner available.
The cooling inlets in the pictures look like they have a sharp edge, this might just be a preliminary drawing but in the final iteration there should be a generous radius around the inboard edges of the inlets (lots of NACA research to support this and you can also see it in how Van's designed the original -14 cowl inlets).
Also, the top view drawing you provided does not appear to have any engine offset. The RV-14, like most low wing airplanes, was designed with the engine angled several degrees nose right to help reduce the amount of nose right rudder/trim needed due to P-factor. Obviously this mounting angle affects the engine mount, forward cowl shape, and possibly the fit of the ducting as well. Curious why DH doesn't appear to be implementing any offset into the design for the -14?
Mark,
Thanks for the comments, and the detailed drawing. I reached out to DeltaHawk so I could better respond to your questions/comments. I'll address them in the order you mentioned them.
Regarding the top surface of the cowling and how it intersects with the fuselage: DeltaHawk says their design is driven partially to accommodate the flywheel of the engine (see pic below). That said, their experience is that the break in the plane (relative to the fuse) is more noticeable in CAD renderings than it will be in real life. Additonally, the top of the outersides of the cowling (left and right outboard sides) will be almost exactly in line with the plane of the fuse - its only as one moves closer to the center portion of the cowling, the angle of the plane diverges a bit from the plane of the fuse (to accomodate the flywheel).
The Spinner: Both the Cowling and the Spinner are carbon fiber and purpose built for the DeltaHawk application. It will be part of the FF kit and supplied by DeltaHawk.
Additionally, and in anticipaction of someone asking about this, the cowl will be comprised of 4 pieces: the Upper, the Lower, and two pieces directly behind the spinner. I am ecstatic about this as it should side-step one of my pet peeves' with the Van's cowl (or with my own abilities to deal with it!) - that is the gymnastics required to remove the lower cowling without scraping it up against the prop or spinner. I don't know if removing the lower cowl is a big issue on the 14A, but its a pain to do on the taildragger. DeltaHawk is also putting an Oil Drain Door in the lower panel, so oil changes can be accomplished without removing the lower cowling. And, remember, there are no spark plugs to change - so, yet another reason removing the lower cowl should be a less frequent chore.
The Cooling Inlets (in the cowl): DeltaHawk say the inlets were designed using NACA profiles and they have done extensive modeling to optimize the expected airflow conditions. Again, the CAD drawings were just to show a rough sketch of what the design will look like. Also, the inlet ducting will be sleeved to the inlet cowl.
The Off-Set of the Engine: DeltaHawk says that according to Vans, the RV14 (stock) does not have an offset. But, Generally, the off-sets for planes of this size and power combination would be less than 1 degree. That said, if flight testing indicated the DH RV14 would benefit from a bit of off-set, it would be easy enough to shim the mount (and, then build later mounts to reflect this).
I hope I've addressed your comments well enough. Its clear there are a number or VAF members with useful knowledge and experience, and we appreciate the extra eyeballs and feedback.
Craig
Mark,
Craig
Ok thanks, I'll reserve judgement on the aesthetics for the final product when the airplane is finished ;). As for the 4 piece cowl, agree that should make removal/installation easier around the prop/spinner area, although the tradeoff will be increased fastener count to remove/reinstall. And the more parts & mating surfaces, the harder it is to get a nice fit all around...but with modern CAD/CNC tools used to make the molds directly and the stiffness of carbon fiber, the parts should fit very well 🤞.
Regarding engine thrustline offset, interesting that Van's says there isn't any on the -14. I don't have my finish kit yet...I know my -8 had it and assumed all RV's were that way. You can clearly see the offset on the spinner in Van's 3-view drawing of the RV-14, but perhaps that was only used for the prototype and removed for the production kits. One note, you can't just add shims to the mount to produce an offset thrustline (unless you don't mind swinging the entire prop/spinner to the right of fuselage centerline). All low wing aircraft I have looked at that have the thrustline offset to the right do so by keeping the front of the crankshaft on the centerline of the fuselage and moving the back of the engine to the left of centerline. But anyway, if the stock -14 doesn't need offset thrustline, the DH powered one probably won't either.
Hi All,
Just a word on offset. There is a noticeable amount of right thrust in the stock Lycoming setup. The aft side of the engine is offset left in order to achieve this right thrust line while maintaining a centered prop shaft at the forward edge. Please consider double checking this.
I love your progress!
-George
All,
Regarding the off-set (and, a few other things):
I have gone back to DeltaHawk to confirm their understanding that the RV14 does not have off-set. They are quite certain that was what they were told from their contact at Van’s.
That said, the project is at the point where the mount is fabricated and lots of other things are well along, too. Its felt getting the plane finished and flying is likely the best strategy to further evaluate the overall design and performance of the engine package.
On that point, one of the primary goals of the flight testing is to determine what must be tweaked to finalize the whole package for general consumption. Possibly, that will include adjusting the off-set, or who knows what else. An area being given particular attention is the effectiveness and efficiency of the cooling systems - much work went into their design, but as most folks know these systems are notoriously complicated in real life vs on paper/computer.
Unfortunately, there is not sufficient time to complete the plane and test fly it before Air Venture - but, as I mentioned before, DeltaHawk plans to have the FF package mounted to our fuselage on display there. After that, work will continue at Synergy Air (Eugene) to complete the final assembly and flight testing.
Also, related to all this is that DeltaHawk is currently in development of the next iteration of the block used in the DHK180/200/235 engines. Based on the data/experience gathered to date and from the use of the engine in the current (flying) test-beds (Cirrus, Cessna, etc), DeltaHawk refined the design of the block. Two of the many outcomes of this exercise are a weight savings of about 10-12 pounds and a slightly smaller diameter flywheel. Neither were primary goals of this process, but both will be of value in the application of the engine on the RV models (I think this is an example of 'serendipity'!). The new block will require modifications to the mount that was built for our current test plane, and will allow for some tweaking of the cowling design (to even closer replicate the original Vans design). It may be more apparent now why DeltaHawk is anxious to get our current plane up and flying so they can move forward with a final version with the new, lighter block (200 hp model). And, additionally, a very refined FF package that folks can order.
Lastly, DeltaHawk wanted me to convey their sincere appreciation for the interest in the project and the feedback from the forum. They are listening and learning from the collective knowledge and experience of the forum's members.
Craig
Something else to share…
Here is the panel we will be using in the DeltaHawk RV14. There's a lot to unpack here, so look at the schematic and the panel rendering first and then the comments below should mostly make sense. Hopefully, I did this correctly and the pics have enough resolution - I was able to zoom in on features after posting.
Back Ground: The panel for the DeltaHawk project was originally built about two years ago by Aerotronics (Jason Smith’s outfit in Billings, Mt). He's done countless panels for Synergy Air in Eugene for RV builders - and, is almost exclusively used by the RV14 builders there. The panel was originally intended to be in my 'next' RV14 - which fortuitously became the test plane for DeltaHawk. The original design was a new iteration of the panel in my current RV14, with some minor modifications to allow a co-pilot to have more access/control over the avionics. The biggest change vs the old panel was the addition of a 7” G3X on the co-pilot side. Now, with the introduction of the DeltaHawk engine to the mix, there are a few more alterations.
Features - In General:
Sharp eyes may notice the additional real estate on the DeltaHawk panel vs a stock RV14 panel. It comes from two (2) sub-panels - to the left and right of the throttle area. Both lightly recessed (towards the firewall about an inch). This idea came from an RV7 built around 2000 by Mitchell Lock – long before he joined Van's and became their CEO (I purchased this RV from Mitch in 2003 and accumulated about 1000 hours on it before selling). I never found the lower panels to hamper clearance for my legs (I’m just shy of 6' tall), and the added real estate opened layout options for the upper panels. On the DeltaHawk panel most of the switches are located on the lower panels. There are also some circuit breakers - but most of the circuitry is routed through the VP-X electronic circuit breaker system (it didn’t have the capacity for all of the circuits in this panel).
The Panel is set up to allow two (2) pilots to share tasks, although it will function for a solo pilot just fine.
Avionics:
Full IFR Garmin Set-up:
GTN 750i
G3X (10” and 7")
Remote Audio panel, Remote Transponder, Remote Comm2 - all accessible thru the G3Xs (IMO the G3X interface is superior to the head mount for these items, and it frees up significant space on the panel for the TVs).
Auto-Pilot
Connexts - for bluetooth streaming
Additionally, the DH panel has two layers of redundancy. First, dual G3Xs allow for reversionary mode should one unit fail (much like having a G5). Secondly, there is accommodation for a Stratus/Sentry and iPad(s) running Foreflight. Should the whole panel go dark (unlikely, but one never knows) - one could navigate or manually shoot an emergency approach using the ADHRS generated from the Stratus/Sentry and displayed on the iPad. The iPad and the Stratus/Sentry have dedicated USB charging ports, but also have internal batteries so they will continue to operate for quite some time in the event of a power loss.
Specifics on the various sections of the panel:
Lower Panels:
No Mixture Control Knob
. The DeltaHawk engine doesn't use one. It has only Throttle and Prop Controls.
Switches: Laid out generally in order of use (left to right). I will only cover the ones that may need some 'splainin'.
“EFIS” switch: Located to the far left since, with the Garmin, its good to power up the G3X asap, as all the engine gauges are displayed via its MFD. One would want this up and running before engine start and it takes about 30 seconds to power up.
Start" switch: Replaces the Keyed Ignition one sees in most Lycoming installations. Hold the switch 'down' to heat up the glow plug, then hold the switch 'up' to start the engine.
“Idle Gov” switch: This is particular to the DeltaHawk engine as compression ignition engines are difficult to control at idle. The Idle Governor works in conjunction with the fuel control unit. The idle governor, when turned on, will ensure the engine never operates below 1200 rpm. This needs to be on a pilot operated switch to shutdown the engine. (*simplified* shutdown procedures are to turn off idle gov and bring power lever to idle).
Fuel Pump” switch: This is located on the right sub-panel, a bit out of the way – as its function is primarily as a back-up to the engine's two (2) mechanically driven fuel pumps. The delivery fuel pump sends fuel from tanks at about ~50 psi to the high-pressure fuel pump. The high-pressure fuel pump sends the fuel at very high pressures to each injector. The electrical pump is a backup for the delivery fuel pump and is an FAA part 33 requirement. DH is still developing the fuel system procedures; typically, the boost pump is activated during start-up, then turned “off” at taxi commencement, and then remains in the 'off' state. The G3X is configured to indicate low fuel pressure. If this were to happen the boost pump should be turned “On”.
Emergency Engine Stop Control (pull cable): Required to allow for two (2) methods of shutdown. Typical shutdown is completed by switching “off” the Idle Gov and bringing the power lever to “idle”. Since this is a compression ignition engine, the secondary method of shutdown is to pull the Emergency Engine Stop. This cable will close off induction air, quickly shutting down the engine.
Left Upper Panel
iPhone: The schematic doesn’t show the details well, but we have an iPhone Max (on an articulating mount) to the left of the G3X. Again, personal preference. Having put the iPhone in about every conceivable place in the RV7 and the RV14, this seems to be one of the best options for readability and accessibility. A USB outlet is adjacent to the mount for charging the phone flight. Personally, I tend to use the full-sized iPad (on the right side of the panel) for navigation and other stuff, but its also handy to have the iPhone to access checklists (foreflight), checking weather along a route, and managing playlists (bluetoothed through the panel).
Cabin Heat: Heat is NOT supplied via a heat muff on the exhaust, instead it taps into heat from the coolant hoses. The heat system is located aft of the firewall (other than the coolant lines that supply hot coolant to the heat exchanger) and sits against the firewall above the exhaust tunnel.
The Cabin heat control cable controls the flow of coolant through the firewall. With it pulled, coolant will flow through the cabin heat exchanger (wouldn’t want a 200F heat exchanger sitting in the cabin on a hot day). There are air diverters/ducting to direct the heat towards pilot/copilot feets.
The control knob controls the speed of the fan to recirculate the air through the heat exchanger. This system eliminates the risk of CO and the need for the cabin heat doors.
Warning Lights: Probably all are self-explanatory except the "Idle Gov". This is to warn the pilot the Idle Gov is not engaged (once the engine warms up, it should be engaged for the entire flight). Idle Gov light will illuminate if the Idle Governor is not receiving power.
Center Upper Panel:
Overall, this area doesn't need much commentary. While the Comm2, Transponder, and Audio panel are all remote mounted (accessed thru the G3X), our preference is to have the actual panel head for the Auto-Pilot. Personally, I use the AP in probably 80% of my flying. Even when not in IMC, the AP is being used to hold altitude, climb/descend, steer with the heading knob, or follow a route in a flight plan. Hand-flying the plane is great, but on many flights its very enjoyable to set the AP, listen to some great music, and enjoy the amazing scenery! Having the AP head below the GTN works nicely as it enables easy back-and-forth with the Throttle/Mixture controls.
Right Upper Panel:
Mostly self-explanatory again. The dark matter on the right represents a full-sized iPad. It doesn't show that well on the schematic – especially in that with the mount we use, the iPad can be positioned in almost limitless orientations. I currently have this set-up in my RV14. It uses a MyGoFlight articulating mount - the iPad can be flat against the panel, rotated, tilted, or even extended over towards the pilot (useful when flying solo and one doesn’t want to strain to see/reach the iPad). A USB plug for in-flight charging is located next to the mount (behind the iPad). Also, behind the iPad is a glove box.
Astute observers who have not fallen asleep from my long-windedness, will note there are leading edge light controls above the 7" G3X and may wonder why these are necessary when the lighting switches on the lower left panel seem to cover all the bases. It’s for more lighting - especially when landing on a grass strip in the middle of Nowhere Mountains. The Aveo Zip tips are nice, but they lack a bit of forward lighting for this type of venue. So, we're wired up for an off-road set-up, but have yet to decide on which brand of lights use. Looking for something like "Elk Spotters 1000". We’ll be visiting all the light guys at Air Venture this year.
Few Random things:
Inogen Oxygen System
. We will likely be using Windblade's Inogen O2 concentrator. I use this in my current 14 and love it. It’s to be ‘hard-wired’ and the unit will sit just below the throttle area (Van's has a slanted panel some folks use for circuit breakers down there – we’ve converted it to hold the Inogen Unit). No tanks to fill (!!!) - it literally concentrates O2 from air in the cabin and delivers it via a cannula to your nose. Its approved for use up to18'K msl (there are asterisks - talk to Tom at Windblade for info).
Control Sticks: We are using Tolsten. Been very happy with them in the past. Functions: PTT, CWS (control wheel steering), AP disconnect, Freq Swap, Flaps. Can’t recall, but I think we may have allowed for the leading-edge lights to be controlled by one of the little hidden buttons below the PTT switch.
Headsets: The plane is equipped to use both Lemo and traditional jacks for the headsets.
So not to be a Danny Downer or Tinkle on anyone's parade.
Most of it was covered about. Size and weight of the RV-14 was made for 200 to 210 HP. So the Delta Hawk is a little less. Weight? Cost WOW.
Delta Hawk flying in an EAB I know of one. A Twin Velocity flying with two Delta Hawks. Performance? Would be nice for them to chime in with data, and compare it to other Twin Velocity's with Lycs.
We shall see if they get takers EAB or STC for certified planes. I don't see Cessna, Piper, Circus running to put this engine in yet.
Based on HP, Cost, unknowns, it is a hard no for me. For those who want to experiment, have the money I hope it works out great. The OP seems excited about it. I hope Delta Hawk can deliver on schedule and swifter than past projects, and it preforms as promised.
Not enamored with alternative engines for me personally. Which leads me to my favorite quote about "alternative engines" about 20 yrs ago.
"The Best Engine Conversion is take $25,000* and convert It Into a Lycoming" Richard E. "Dick" VanGrunsven
* Not adjusted for inflation., add $10 or $15K depending on engine, still cheaper than $80K.
I don't think this was the type of engine that he was referring to in all fairness. I think that was more a shot at car engine converts.
I think this is a real aircraft engine with all the associated development costs unfortunately. Nothing is going to be cheap anymore - not even a real Lycoming.
Case in point:
GMC,
Please check out the whole thread. Things at DeltaHawk may be a bit more evolved than you suspect. The thread has a lot of information directly related to the points you’ve brought up and more.
But, let me address the points you’ve brought up specifically:
Power: The certified DeltaHawk engine is 180hp, but there are three variants all essentially identical in weight and size: 180, 200, and 225 hp. All are turbo/supercharged. We’re installing the 200hp version in my RV14. We’ll be flight testing this fall. Based on the performance numbers in the other DeltaHawk projects I suspect folks are going to be very happy with the performance of the DeltaHawk in the RV14.
The engine is already in a number of planes. Including a Cessna that was the basis for a detailed Cessna Pilots Association article that’s linked in a prior post. It’s also been in a Cirrus for about two years now (the plane that was used for FAA certification). The results have been impressive. Piper recently announced its working with DeltaHawk for an STC to put the engines in the Seminole (twin). While I can understand your skepticism regarding the industry’s embrace of DeltaHawk from past history, I believe things have changed recently.
On overall cost. Have you priced the Firewall Forward of a Vans RV recently? Just the Lycoming engine (IO-390 TB) alone has gone from $44k to $70k in less than three (3) years (sadly, pretty much in line with the prices of a lot of things over that time). I know this since I bought/received my lycoming 3 years ago (June 2021) for that amount, and just priced them a couple weeks ago on Van’s website. Not to mention, it’s a 3-5 year wait if one ordered an engine today. Additionally, and this seems to be overlooked by many, DeltaHawk is targeting a complete firewall forward package (prop, engine, mount, cowl, etc., etc) for about $110k - again, see a previous post for details. The same components for the lycoming installation are over $100k. Once the significant operational costs are factored in, the DeltaHawk handily beats the Lycoming set-up.
The Dick VanGrunsven quote shouldn’t be taken lightly. And, I’ve seen countless alternatives to the lycoming come and go over the 35 years I’ve been involved with GA/EA. But, I think this one is different. That’s why I volunteered my RV14 project to be the test bed. As are you, I’m skeptical, but the level of involvement I’m enjoying and what I’ve witness so far has lead me to be very optimistic regarding DeltaHawk and the engine. Please read all the posts in the thread - there’s lots of good information there. I will continue to post through the remainder of the build and the flight testing - good, bad, and in-between. I’m a Van’s RV builder/pilot first and foremost and the perspective I’m trying to present is primarily from that angle.
Thanks for the comments and engagement.
Craig
GMC,
The Dick VanGrunsven quote shouldn’t be taken lightly. And, I’ve seen countless alternative to the lycoming come and go over the 35 years I’ve been involved with GA/EA. But, I think this one is different. That’s why I volunteered my RV14 project to be the test bed. As are you, I’m skeptical, but the level of involvement I’m enjoying and what I’ve witness so far has lead me to be very optimistic regarding DeltaHawk and the engine. Please read all the posts in the thread - there’s lots of good information there. I will continue to post through the remainder of the build and the flight testing - good, bad, and in-between. I’m a Van’s RV builder/pilot first and foremost and the perspective I’m trying to present is primarily from that angle.
Craig
I truly hope they crack the code; the industry needs new players that are successful.
That said, I've been waiting the better part of two decades, and it STILL isn't available. At some point in the build, decisions have to be made in order to move forward.
Again, I hope it is successful; I would consider it for my next build...however...it will need to be available. Of course, now that I say that out loud, how available are the run-of-the-mill lycomings?
GMC,
Craig
Yes Sir. I read every post and there is some missing info. I have followed alternative engines (meaning not Lycoming) the mid 1980's. I have followed Delta hawk for over 20 years. I know a lot about it. I am also opinionated, I admit that. I am not keen on deviation from Van's plans, especially on recommended important parts, the engine, prop. I am conservative with aircraft designs and mods. That is me.
Yes alternatives "work" but most are not as good as Lycoming (overall for me) in my opinion. What do I mean by not work as good? One or more: Performance, Reliability, Ease of Installation, Maintenance, Weight, Value, and Resale. The exceptions can match just match a Lycoming in some categories, but all are by DIY'er, with time, skill, money, and determination to take a stock automotive engine from nothing to mounted in the nose of your RV. The off the shelf ones like "Eggenfellner" was not great in my opinion. However Ross of SDS ignitions has a Subaru powered RV-6 that he has been tinkering with for a long time. It works, but he is Ross who makes CPI-II ignitions. He knows stuff. Average builder does not have the wherewithal to get similar results. He also has had issues. but again time, perseverance, resources, skill, desire... he has worked through them. In the end it is not faster, lighter or aerobatic and definitely not cheaper.
We love experimentation. I have seen in my years in EAA over 30 years all the next "Lycoming Killers". I know no one is saying that here for Delta Hawk, that it is a Lycoming killer. Just the price is a market issue.
Alternative engines, Mazda 13B, Subaru, Ford V6, Buick V6, LS 3 V8 all been done. For the most part the planes that swap out a Lycoming for one of these are heavier, slower and fetch lower resale. Now there are exceptions as mentioned. People have finessed with very cleaver work and 1000's of hours to get good performance and reliability. Still not better than a Lycoming.
The BIG SHOW STOPPER for me, which Delta Hawk does not have, with most alternative engines are PSRU's. All the car engines (with exceptions) run higher engine RPM and use PSRU. I do not like them. Belt or Gear they to me are a weak point and have proven to be problematic. Again not unilateral guaranteed to fail, but a weak point. Also it assures you the plane is not aerobatic and often can not use a hydraulic CS Prop. Is the Delta Hawk Aerobatic? I know it supports a hydraulic CS Prop.
I am leaving off the Alternative low HP VW, Corvair, Honda, Suzuki (car), Mitsubishi (car) in the sub 130 HP range, not suitable for "full sized" RV's. However several RV-12's. I am sure are sporting a Viking (Honda Car Engine) or Aeromomentum (Suzuki Car Engine) auto engine based set up. I do like the "Fly Corvair" with the flat 6 Cyl air cooled direct drive with all the mods. VW flat 4 air-cooled was an early auto to airplane engine for tiny planes like Q2 and KR2. I want to like the VW but seen too many crank failures.
There are the boutique aircraft engines, ROTAX, Jabiru, UL Power. I admit I was wrong about Rotax 20 yrs ago. Clearly Rotax being bought in 1970, now part of a global behemoth Bombardier, with 1989 UL912 flat 4, water/oil cooled geared engine, perfect fit for the LSA class of plane, it's an established success. PSRU? Yep it works but not 100% trouble or maintenance free. I have 4 hours of recent time in a RV-12iS. Hey it works and 4.5 gal/hr at about +110 kts. Not shabby. Rotax is no longer an alternative engine. It is the de facto LSA engine. However a top of line UL915 is $44K. That is a show stopper. Also the drag issue of radiators less critical on 100-130HP planes that typically top out at 135 MPH. Drag goes up exponentially with speed. The weight to power is good. I thought the high RPM would bother me but it's not bad. You are turning +5000 RPM up to 5500 RPM in cruise.
The Jabiru another approved LSA engine was bad at first when it came to market 1995. They are on Gen 3 and I hear have overcome the issues of past. AIr-cooled direct drive. fine. However I know people had early ones. Cost them a lot in time and money. So buyer beware, Don't buy a NEW engine until it has service history. Also Jabiru is out of country made product. Not as well supported as "Lycoming".
Last is UL Power. Not against them, direct drive, air-cooled, but feel the reliability and actual pwr vs advertised are not there. Why? I look at UL Power engine user groups. Again cost more than a Lyc. and makes less actual power, not aerobatic. It is lighter and to mount on an RV you need an engine mount extension adapter and longer cowl. All the engineering van did to fit a Lycoming is out the window.
Which leads me to my canned advice, to anyone who cares to listen and is interested in NON LYC power for their RV as specified by Van's the following:
"Before you buy and invest in an Alternative Engine, talk to 3 people who own an alternative engine and are flying it. I do not mean bought it and it sits in crate in corner of hanger. When I say fly it, I mean well over a year and well over 100 hours, better 1000 hours of flight time, at least total. Last is fly in a plane with the engine. and don't accept manufactures claims without verification."
LOVE Diesels. I drive a diesel car, VW TDI and got 51 mpg on a recent short 400 mile road trip. I am all about diesel. The price for Delta Hawk however is too much for me. I very much want Delta Hawk to work and work well. At this point in my life, God willing 20-25 more years of flying I doubt I will own a Delta Hawk. But I want YOU TO. Ha ha.
For me, personally too much risk or should say unknowns, not enough reward if all lines up. I want to bolt up a Lycoming and Hartzell and go fly. Done and Done... I do not want to be a beta tester or invent new things.
Cooling drag - Getting a radiator in an RV that is super low drag is not straight forward. The technology of air-cooled engines, the engine itself, the cowl, baffles is not nothing. It has some serious NACA NASA research behind it and pretty much optimized as good as it gets over 100 years. To be fair water cooled aircraft engines go back to Wright Bros. However post WWII all piston planes zoomed in on air-cooled. It was for reasons. P-51 airframe was made for the V12 and a radiator. Do you want to put a belly scope on your plane. The RV was made for a tractor drive, air-cooled Lycoming. Not saying water cooled can't be done, but it will be more than bolting in a radiator and some glass work on cowl to get optimal low drag.
Question yet to be answered side by side. RV-7/14. - One has Lyc IO360 (180HP) the other Delta Hawk (180HP). Top Speed? Fuel Burn? We expect the Delta Hawk to do better but how much better? We may never know. I find claims often don't meet reality. Now we have ADS-B to spy and tell the story. I looked at an alternative engine RV-8 recently. It was slower than a Lyc powered RV-8. I don't know winds or if they were in min FF Econ... My finding with all the RV's with car engines they are heavier, slower than Lyc versions. There are exceptions and those just match a Lycoming and also lose the aerobatic capability. Resale in Alternative Engine planes also less than a Lycoming built to plans RV. I have been tracking this for +30 years.
Cessna 182 JT-A diesel-engine Skylane dead. Why? As I understand it worked fine but the cost primum to buy vs fuel savings was not enough. There are conversions and may be very desirable in places like Africa. However for now 100LL is plentiful. As I said I drive a VW TDI Diesel. It does get better MPG and fun to drive with low down torque. However a Prius gets about the same MPG (but boring).
70 MILLION passenger cars are made EVERY year (not including trucks, commercial vehicles). How many planes are made all up Standard, EAB and LSA. A tiny fraction of cars. I would say more cars are made in a year than all of GA all time may be? Currently there are about 340,000 GA planes world wide, about 204,000 flown. Remember ONE YEAR 70 million passenger cars made, year after year. So the economics are different. Yes the DA62 at $1.5 million sells with twin diesels. However the market will saturate. It is a tiny 5 place plane. (I read some places 7 place?) A Beechcraft Baron is bigger, holds more and as fast or faster. A nice Baron, used but well appointed, with good times and maintenance is under a million. Fuel burn? Sure higher but if you can afford this, fuel is not the big thing. I think that the calculation of savings from lower fuel burn alone, going to pay for the added expense, is not sound. Not at 100 or 200 hours of flight time a year. The cost of DA62 or Delta Hawk over a 180HP Lycoming is not sound on financial basis.
(* DA62 accident due to loss of power from electrical failure and fuel/ignition dependent . The Baron's engines are independent of ships electrical busses. I will say ALL alternative engines are electrically dependent. )
Delta Hawk did a great thing getting certification. I am impressed, but many aviation things get certification and go no where. New airplane design certified and goes no where. Only time will tell if this is a hit or miss. Even if not popular does not mean it is bad. Just a Market thing. Aviation is a tough space to make money. A new fixed gear single piston engine Cirrus cost what?
I don’t think anyone on this thread is in disagreement with your comments on the history of alternate engines that started as auto engines and were converted to aircraft use. Maybe the excitement about this new clean sheet design is because it’s not followed the same path. Hopefully Vans will support this option on the RV-14 if Craig and his buddies get this thing out there and flying with some good data (keeping my fingers crossed). You may not see Cessna or Piper running to get an STC for this engine but I do. Unlike the past where 100LL was not an issue, the availability/cost of 100LL/UL100 in the near future will, in my opinion, drive the interest of aircraft manufacturers and the EAB market towards this engine. The cost delta between a UL915 and a IO320 is starting to narrow, my guess is the same will happen between the IO-390 and the DeltaHawk. I sincerely hope that Lycoming figures out the production delays, can keep their cost down, and will provide a company approved option for running on alternative fuels. Unfortunately, I think Lycoming is betting on the fact that plenty of people out there that will continue to buy their products regardless of production delays or cost increases and that for now, 100LL is plentiful. I hope I’m wrong……
Slow going right now and not much noteworthy of posting. DeltaHawk has been accumulating the custom parts that will make up the firewall forward package so we can assemble it all for testing. And, Jason at Aerotronics is busy modifying the panel. That said, the actual engine we’ll be using in N245WM (yes, just received the letter from the FAA today) is being built and below you can see a few photos from that task.
We’re still on track to have the fuse/engine set-up for all to see at Oshkosh - and, the Synergy Air group is ready to then do final assembly in Eugene. We’re targeting late September to begin test flights.
Craig.
Thank you for the updates! It is very interesting to follow along And I'm looking forward to seethe the Oshkosh display.
A questions regarding the crankshaft and the prop flange.
It appears they set up the prop flange similar to a Lycoming. Was they any consideration to using a Continental style prop flange? In my experience, a prop is far easier to install on a Continental vs a Lycoming.
Both are fine but if I were choosing.....
Craig.
Speaking of prop flanges, it appears it is set up with 5 long and 1 short bushing? Most prop flanges I have seen are 4 and 2 including my 2 Lycoming engines. By the 5 and 1 method one can't re-clock 180 degrees without knocking a bushing or 2 out and changing. I have seen some Lycoming prop flanges set up 5 and 1. Is there a reason or benefit to 5 and 1 vs 4 and 2?
Gents,
I haven't a clue. But, fortunately, I know a few engineers at DeltaHawk. I reached out to them and asked them for the reasoning behind the design, or at least a damn good sounding guess (they're on notice that this group is at 4-chan levels of BS detection!). Just dont ask about the Fetzer Valve.
Craig
Progress report: Little to report this week. That should change by next week as we get things prepped to show at Air Venture.
Somewhat related....I need a room at Air Venture. Does anyone have a spare room in where ever they are staying? Happy to pay. As usual, I waited much too long to tied something down...
