I am in desperate need of some advice on attaching the stabilator. After much wrestling I've been able to get everything to line up and I have gotten bolts in both of the bearings and I have even been able to engage the threads on the left side. But try as I might. I simply cannot get the bolt to engage with the nutplate on the right side. I've tried everything. Yesterday I took it off and I ran bolts through all lubed up and then today reattached and I'm having the same problem. I can get the bolt on the left side to engage but I cannot get the right side to engage and an additional problem is the design of this. There is almost no room to work.
Has anyone encountered this situation before and if so, do you have any advice at all?
