Oh, one more thing. The RV14 baffle cutout under the governor is is sized for a hartzell. My jihistroj is a smaller diameter so that gap was too big for the pre-cut rv14 baffle rubber to close the gap. I see you've got the PCU-5000 governor which I think is basically the same size as mine so if you're using the rv14 baffle kit you may have the same issue.
Since I was modifying that area anyway, I made another fat C shape out of aluminum to bridge that space. I ended up with a gap around the whole governor of about 1/4" which I just filled in with RTV. Theres no rubber baffle material at all around the governor.
I debated on using nut plates to sandwich this all together but ultimately decided that it was overkill given how infrequently you have to take that governor off. I ended up just using pop rivets in that area. If I ever have to remove the governor it's a pretty small job to cut the rtv and drill out the pop rivets.
If this picture doest make it clear you can shoot me a pm. I'll help however I can
