My own thoughts....
I have no skin in the game, my RV-10 is already flying, however I feel it is important to put things into perspective, at least from my point of view should it help anyone else.
I have read through all of this, and other, threads and watched the "long" video as well. All I can say is that anyone that calls out from the sidelines, without going to Vans and working through the details with them should really not make assumptions associated with possible scenarios on which there is no evidence.
Is there a possibility that this is all a "coverup"???? Yes. Possible... Likely???? I would say based on the history of this organisation, of Van putting his name to it... and the work that has gone into proving these issues through testing and scrutiny of Aeronautical engineers and third parties... I think it is pretty evident that this is highly unlikely and it is structurally sound.
If anyone wants to cast a dispersion, they should go to Vans and get the data, work the problem and "PROVE" that the information is incorrect before they "guess" at possibilities years down the road....
I look at these things in Black and White in an attempt to make sense of things.
In this case look at it like this.... I am not an engineer, and definitely not a aeronautical specialist engineer, and have needed to trust in Vans in the engineering of a PLANE..... forget the details of each rivet, but in the baseline that the plane they designed is safe... Now if I trust at the basic plane level, then why would I then question the veracity of the detailed level. Detail so low that it is required to form part of the the structure and the whole aircraft design. This would be after it has also been rigorously tested and presented to industry specialists, only then to question its accuracy with no data to support my argument.
To me that is just not logically sound or rational. I either trust them, or I don't. My baseline faith that the Aircraft is Safe is in the legacy that Vans wants to leave behind on this industry, and in his pride at a what he has been able to achieve. I have met the man and in that I trust the man.
The science, independently, has been effectively proven, and yet people with no data or science to prove otherwise are stating that this is "dodgy". Really??
I suggest that if you believe that this is a problem, then prove it wrong. Please, it would be of benefit. In the words of Matt Damon, "Science the **** out of it". Otherwise, anything said to the contrary would just be a guess.
You would not accept this if Vans did that, made statements with no facts, guessed at the safety of these parts.... so why should we accept or even listen to any argument to the contrary without demonstratable data...
Just my 0.02 worth. Take it how you like....
