Leaking radiator troubles - RV-12iS
The 12iS radiator has both fittings on the bottom.
I stand corrected. The Alloyworks https://www.alloyworksplus.com/prod...ralight-rotax-912i-912-914-ul-4-stroke-engine is a drop in for the standard Rotax radiator. https://www.rotax-owner.com/en/rotax-blog/item/25-newrad
Which is the same listed by Lockwood https://lockwood.aero/shop/engines/ROTAX_912ULS/21
Clearly the radiator on the RV12iS is a custom build specific to the plane not the engine. Not sure why other than maybe left hand cowl shape or width. The hunt goes on both for cause and replacement.
No radiator shops can repair it? Back in the day, it was possible.
:confused:
The top radiator shop in Lexington said they couldn't repair mine with any level of confidence it would perform sufficiently. Admittedly mine DID have Marine-Tex in the bottom two rows of fins.
Perhaps someone who has not corrupted their bad radiator could attempt having a radiator shop repair?
Clearly the radiator on the RV12iS is a custom build specific to the plane ....
This is correct. Rumors have it that Vans found out that some customers were attempting to go direct to their vendor to get a replacement. This triggered a "cease and desist" order so they maintain a monopoly on the sale and distribution of that part.
Not having ever built a custom radiator, I make some broad assumptions of how much material/labor is involved. It seems that $800 would make it worthwhile for a custom radiator service to crank out a batch and provide some competition in the market. Maybe?
I call BS!
If the rad is aluminum it can be fixed!
Silver solder and heat, even a plastic rad can be fixed.
Their is plastic that is used like solder and it holds.
Sorry for the rant! Find another shop and when asked its for your kids go-cart.
I understand a bit better now. If that is a Van's supplied part, not Rotax, then Van's is constrained by the ASTM rules for LSA and part/kit supply. However, if built ELSA a different radiator could be used if (big IF) someone wanted to fashion the rather unusual mounting method after the AWC is issued. Given the propensity of radiator failure, seems to me there may be a small aftermarket demand for a better solution similar to that for the filter to bypass fuel line.
Yes, as an aluminum radiator, assuming its not full of pinholes from internal corrosion, a competent shop should be able to repair it. I suspect "aircraft" scares a lot of them off, don't need the risk.
JJR
radiator leak repair
A friend of mine has an RV12 and has had 2 radiator failures. He's 87 and loves to fly, so I wanted to help him get back in the air. His newest radiator had a small pinhole leak on the lowest row of water tubes. It was coming from a spot where the tiny fins are attached to the tubes. The repair method I chose to use may not be long term. Only time in service will reveal if it's a good method to salvage an existing bad radiator. I cut out a small area of the outside of the tanks to gain access to the lowest water tubes. Once I had access I used a very small stainless steel wire brush to clean off the aluminum around the water tubes. After that I carved 2 small pieces of balsa wood to be inserted into the water tubes. The wood plug is slightly oversize. Balsa is soft and it's easily compressed using needle nose pliers. I squashed it to the size needed to fit into the water tube. The balsa expands once it's pushed into the tube to tightly fit the tube. I pushed the wood in about 1/8th inch below the end of the tube. I used regular overnight cure J B Weld epoxy to fill in those 2 water tubes and then built up a mound of epoxy over the 2 tubes to encapsulate them. By doing this on both ends of the radiator you prevent any water from going though those 2 lower tubes. After everything had cured for a minimum of 24 hours, I welded patches over the areas I had cut out. J B Weld is good for up to 550 degrees F. once fully cured. Do NOT use the Kwik Set J B Weld for this type of repair. It does not have the same tolerance for heat as the slow cure J B. When I did the welding, I did it in short increments and cooled the area immediately with a wet rag to keep the heat affected area below what would potentially damage the J B Weld epoxy. Once it cooled, I did more welding and repeated the procedure until everything was fully welded. My friend has only flown his RV twice since the repair, but so far it's OK. He flies at least 3 - 5 times per week. If it starts to leak again, I'll post something in this thread. He'll likely replace the radiator with the new improved version from Vans once they become available. For now, he's very pleased that he can fly again.
Cheers
Enzo
Doing this looks he lost about 10% of the cooling capacity. Has he noticed any change in temps at high performance levels?
Don’t know about everyone else, but my coolant temperature barely moves above the minimum so I can’t believe losing that channel would have a significant impact on cooling.
radiator repair
My friend often has to add tape to the radiator opening to get his temps up. Even in the summer here at KSZP he told me that his RV never runs hot. I chose this repair method to get him back in the air as quickly as possible. He's 87 and knows his flying days are limited. In the old days of brass and copper radiators it was common to solder up both ends of a tube that may have received rock damage etc. A car radiator has more water tubes, but the principle of blocking leaking tubes is the same. He has another RV radiator that leaked in the same spot as the one I repaired, but we haven't been able to get it to leak again to verify the leak location. He will buy the improved radiator if it becomes available. He's a friend and I didn't charge him to make the repair, but it shouldn't cost a lot at most shops that can weld thin aluminum. The big tubes of the J B Weld cost $20, plus tax at our local auto store. He's flown about 8 hours since the repair and it's still leak free. Nothing was done to add stiffeners to the radiator core to make it stronger, so maybe it will fail again in another spot. If so, we're confident that it won't leak from the 2 lowest water tubes I blocked off with the epoxy. The images show how simple it is to do the repair. If you can weld or you have a friend that can weld, your cost will likely be just for the epoxy.The biggest issue is being careful in keeping the welding heat as low as practical to minimize affecting the cured J B Weld epoxy. It's good for 550F according to the label.
Cheers
Enzo
My 12 is an early SN and has ULS engine now with 900TT. If I had an RV12iS with leaking radiator, I’d incorporate your repair. There’s no telling how long it will take Van’s to issue a fix for this problem. Chapter 11 bankruptcy dilutes engineering efforts….
My radiator developed a small leak (see post 41 for details). I was able to stop the leak with radiator epoxy (8+ hours flying since fix), but ordered a new radiator as I didn't trust my "fix" to last very long.
The new radiator arrived yesterday and lacks the tabs to attach it to the oil cooler (see photo). I can't find any plan revisions or SB's that address this change. I'm assuming the change in design is intentional and to address leaks that I and others have reported.
Does anyone have information regarding installing the new design? Does it only attach at the top? I've contacted builder support but thought I'd check in here while waiting for a response.
A (potential) fix has already been engineered and the holdup was waiting for the Service Letter to be written up and published. Sadly this bankruptcy situation will likely delay this write up indefinitely. I can see why the formal procedure of publishing a Service Letter is necessary for the SLSA versions but I wish they would just share the improved mounting method with the rest of us (informally) without the long wait for engineering dept., legal dept., etc. approval of an official Service Letter.
I had added an $800+ radiator every 200 hours to my fixed cost budget.
Unfortunately I went to the hangar today and found a small puddle of orange coolant on the floor beneath the cowling. This is how it begins. It is not even 100 hours since the last replacement. I even balanced the prop to a very small vibration level so that isn't the culprit. The last radiator lasted almost 200 hours with the prop out of balance and this time not even 100 hours.
I guess I will have to budget an $800+ radiator each year.
Given the ongoing -12iS radiator issue I've been thinking of alternatives to continuing to buy an $800+ radiator every year. Here are the first two considerations:
1. Perhaps a custom radiator (by prchotrod.com or rondavisradiators.com for example) maybe 24" wide by just 4" high could be mounted to the airframe rather than the engine. It could go under the fuselage near the bottom opening of the cowling using a bracket extending down from the firewall through the lower opening of the cowling with additional support brackets on each side that attach to the foot steps. My concern is the introduction of additional drag.
2. Borrowing a design idea from the Zenith 750 by having an horizontal radiator mount frame under the fuselage just behind the lower opening of the cowling forcing all airflow into front cowling openings to exit by passing through the radiator fins. Less drag than an externally mounted radiator.
Commentary on these methods invited and additional ideas encouraged!
I'm sure that when working with the custom radiator manufacturers they can calculate the cooling capacity of the existing -12iS radiator and advise on exact dimensions needed for option 1. above to achieve the same capacity.
I wonder is there is a way to mount the radiator to the cowl instead of the engine. The ULS has the oil cooler mounted to the cowl and the coolant radiator to the firewall. You never hear of them failing.
RV-12iS Radiator
As of this date, the part number was EA RV-12IS RADIATOR and is now
EA RV-12IS RADIATOR-1. Plus there is an upcoming Service Letter (SL-00088) announcing the change to the radiator that modifies how the oil cooler is attached to the radiator.
I had mind repaired at the bottom henge where it connects to the oil cooler.
Waiting 2 months for a replacement.
I just went to the Van's Store and a radiator is not even available, either with or without the "-1" change, for purchase!
A good quality rad shop can fix your rad. Thats if they still employ skills to repair not just replace.
Leaking RV-12iS Van's manufactured Radiator
Yep, Mind was leaking also at the bottom where it connects to the oil cooler. Had it repaired & tested.
Interesting... Van's now has a new RV-12iS Radiator ---Grin
The EA RV-12IS RADIATOR has been superseded by the EA RV-12IS RADIATOR-1, and it is currently backordered. I suggest you call and place a -1 on order so you get one from the next batch that is delivered. Be sure to tell them you are Grounded and need it ASAP.
These radiators are custom made to our specs in Europe and are not available from any other supplier or vendor.
There is an upcoming Service Letter (SL-00088) announcing the change to the radiator that modifies how the oil cooler is attached to the radiator. Additional parts will be required and they MAY be in a kit that includes a radiator, but you'll have to read the SL when it is released to know for sure. I can not supply a copy until it is released.
Tony
It appears that Van's design does not use the Rotax Radiator? The difference in Van's radiator is that it connects to the oil cooler... Rotax design has them in a frame each...?.
The Van's Engineering places mounting stubs attached to a plate. the plate twists on nasty landing? Grin.... Plus Van's hand picked European manufacturer does not repair there product or use Rotax radiators...
My last radiator was full of Marine-Tex repairs and was corrupted beyond repair. I will not make that mistake twice.
However I know that whether a new or suitably repaired radiator is mounted again in the original mounting method it will invariably begin leaking in 100 hours or less. I would like to reconsider new and improved mounting methods that do not include attaching the radiator to the engine.
New design radiators are shipping
I just received the new radiator and can confirm that Vans took our failure analysis seriously and changed the design to completely eliminate any torque or flex caused by having the oil cooler swinging off the lower mount bracket. I haven't seen the new instructions yet (not published yet), but there will be additional parts required to modify the oil cooler mounts.
Photo shows an old radiator on top of a new one. You can see they completely removed the oil cooler mounting and beefed up the lower cross-member so it can't flex. I'm not sure the bridge truss lower bracket is really needed without the oil cooler mounted there, but I'm guessing they wanted to make sure the fix is 100% fixed. The top mount is unchanged.
https://vansairforce.net/community/attachment.php?attachmentid=53032&stc=1&d=1703642394
So the new one is mounted only by the two bolts at the top? Left dangling, and quasi-supported by the thick coolant hoses at the bottom?
I wonder what the retrofit solution will be.. I can't imagine that they'll want everyone to proactively replace the radiators for 745$ Maybe some sort of rubber bushing solution on the lower bolts.
RV-12iS radiator mount mod
This thread came just before I installed the radiator and oil cooler, so I fabricated some brackets to support the bottom radiator flange where the cooler attaches (one on each side). The local DAR approves (it's an E/AB). They are cut from 1/8 x 1 x 1" aluminum angle. Here's hoping they prevent cracking at the bottom of the radiator.
--CT Cole
--CT Cole
Great idea! This is the kind of thing I was hoping to be shared! Would having just one bracket that mounts diagonally work better or just as well? Or even weld a straight piece from the top corner of the radiator frame diagonally to the opposite bottom corner. This would take the entire radiator frame into account rather than just the narrow width of the attachment points.
--CT Cole
I believe you've isolated the majority of the forces there. I look forward to reviewing this thread in about 3 years and seeing if this ends up protecting you from a failure. I expect that it will.
--CT Cole
That looks like a good idea! I am about to install the radiator in my 12iS and I would like to protect against early failure of the radiator. Can you supply any more details of those brackets, such as a larger photo or a drawing?
I didn't draw up plans, but made them to fit the radiator and oil cooler when they were off the engine -- now everything is assembled.
I cut the 1/8 x 1 x 1 stock freehand on a bandsaw so that top and bottom each had a tab for drilling & dressed the edges.
I bent the tab at the bottom so the top tab would fall outside of the rubber bushing used where the radiator mounts to the engine. The tab at the top of the bracket was bent to match the radiator/cooler angle, and I also cut an arc in the top tab for clearing the bushing.
At the bottom, I match-drilled through the radiator mount to make the hole in the bracket. After bolting the bracket & radiator together, I drilled the top tab through both the bracket and upper radiator mount.
Doing that made the fit exact.
I'll attach another photo, at higher resolution, that may show the details better
Thanks. I've ordered some aluminium angle with a view to replicating your design.
The other idea I had was to add some stainless steel cable ties around the radiator, with 3D-printed nylon pillows to spread the load of the cable ties on the top and bottom parts of the radiator instead of it being concentrated on the edges. However, it wouldn't have been clear how much the cable ties should be tensioned. Too little and they would not be effective; but too much could damage the radiator fins and/or tubes.
My power plant kit arrived a few months ago with a few parts missing that were on back order. All of those parts have arrived except the radiator. I was told a few days ago that an SB or SL is being worked on for the radiator and mounts. The new mounts are in but the radiators are not. I was also told that there is a long list of orders for the new radiator and mounts.
Hi folks,
Is your RV-12iS radiator leaking? A little? A lot? Or totally dry?
We’ve been having an on-going issue with multiple radiators that’s pretty frustrating… just trying to see what’s going on with the rest of the community and see what fixes have been done and such.
Thanks. Fly safe!
-Jim
I have a 2019 12iS with 220 hrs TT. Just developed a radiator leak. Front pilots side.
JB
I installed radiator number 6 along with the new mounting system for SB-00088 in March. The kit is well designed and the whole process took about an hour. So far it's not leaking, but it hasn't passed the magic 200 hrs mark yet. I will reserve claiming victory until it gets at least 500 hrs so sometime around Christmas we'll know for sure.
If you do decide to order the SB 00088 kit, also get some hose from Vans ( H151-14" ) since you will need 2 pieces about 4" each.
And hose clamp pliers really help: https://www.amazon.com/gp/product/B07C3LYZM7/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
Also, a little silicone grease on the pipes make sliding the hose on a lot easier.:)
One more thing - after you fill the coolant reservoir you need to crank the engine about 8 seconds to fill the radiator then refill the reservoir before your engine test run.
I thought maybe I was one of the lucky ones to avoid the "Radiator Leak" club. Now I'm in the club.
Details:
  • 166 Hours
  • Prop balanced from the first flight (and blade pitch is matched)
  • cowl clearance is uniform and proper
  • Dex Cool (orange)
  • Leak is small, bottom row, right side (pax side)
  • Incorporated SB 00088, about 20 hours back.
  • Working the notification to the Vans folks.
I had my radiator welded at a local repair shop. Fortunately, I found an old-school technician who could fix it. The repair wasn't due to the service bulletin, as there were no rub marks and it never rubbed. The technician did comment on the quality of the radiator.
Details:
  • 166 Hours
  • Dex Cool (orange)
In light of that discouraging news, I decided to add a couple of rubber washers.
Morning to everybody,
Last year I had a water cooler failure just after 60 hours since new, Vans told me to contact the manufacturer in Czech Republic. I had to send them the broken radiator and they gave me a brand new one. all under warranty.
Few days ago I had another failure ( 200 hours flight time 140 hours since the new radiator installation) so I contacted the manufacturer again but they replied Vans was having issues with radiator design and many other people were experiencing the same issue, they suggested to contact Vans. So I did but no reply from them....
I started to look on internet and I found this forum here.
I also checked on Vans website and I found the SB about new radiator setup. I wonder why Vans never sent these infos on email...
I dismounted the radiator and sent it to a radiator shop hoping they will manage to fix it.
I'm not an expert about aluminum alloy stress and fatigue but it is obvious the design is not the best one.... Just the fact all is directly connected to an engine it is surely not a good idea even if with vibrations dumping devices....
The SB doesn't seems to really change the "faulty design" but just try to reduce and delay the issues... at least this is my opinion.
The oil cooler is still able to swing around lateral and longitudinal axis putting stress on the water cooler frame. The new dumpers will reduce the stress but the source of the stress is still there....
If the shop will manage to fix my radiator I will surely apply the SB but I'm really thinking to design something to make the frame more resistant.
@CTCole did a nice job putting those 2 bars, but with the modified radiator the lower radiator mounts will not be available anymore so another point must be found.
I'm also considering to use 2 nylon cable tie around the whole frame to keep it more rigid, this will be surely the cheapest and faster way but not really nice to see... (ties would be visible on the radiator forward side).
Vans should consider to redesign the whole radiators setup...
I'll keep you posted.
Giovanni
Question for the community.
1.) perform the SB-00088
or
2.) wait till a possible leak and order the newer stuff to put on?
I know, possibly a dumb question…
2023 SLSA RV12is 130 hours
or
Not a dumb question, at all. Some have already performed this service bulletin and others have not. As you know my opinion already I will mention the reasons why. The leak begins between the radiator lower frame and the bottom row of cooling fins. This is believed to be the result of vibration and outside forces such as at start up. I feel that cutting the radiator framework will produce a lot of concentrated vibration and perhaps even some twisting of the frame as the cutting takes place. My plan is to wait until next failure and replace with the new design.
Leaks begin around 200 hours; you already have over 60% of the time it typically takes for the leaks to begin and the cutting just might get you there sooner. Take a peek at Post #90 by Mike B. He performed the SB at close to the same hours as yours and his began leaking 20 hours later.
In my case, my “leak” occurred 100 miles from home base. And it didn’t just leak a little, it drained the entire cooling system on the ramp where I shut down. On checking the EMS logs, no signs of increase in coolant temperature up to shutting down. My assumption is the shock of the engine stopping and jerk caused by the gear box was the final nail in the coffin. I had 330 hours when it occurred. So, it just gets down to playing the odds regarding applying the SB. And mine showed no signs of rubbing against the cowl.
or
If you just perform the SB the leak will probably come in anycase....
If you change the cooler with the new version we still don't know if it will completely solve the problem... (to me the source of stress and potential failure is still there)
The setup is reinforced so it may last more but we don't know for how long yet...
I had my cooler rebuild by a local shop, the problem is usually on the first bottom cooling fins row, I asked the shop to isolate the first row (basically they closed the first pipe) so in case of another failure i should't have any leak. I also placed 2 aluminum bars trying to reinforce the frame structure (in my opinion the stress is the oil cooler swinging moment around the lateral axis bending the lower water cooler frame, rolling moments should be damped by the already existing grommets)
I'm still waiting for the SB from vans, so next week I should be able to test the new setup in the 35°Celsius summer and see if the reduced water cooler surface will be enough.
So, in your case I would wait if you only do local flights, I would change the whole thing if you usually do cross country just to reduce the chance to be grounded somewhere far away...
Applying the SB on your old cooler may delay the problem a bit....
Adding my airplane to the list of radiator leaks....
Approximately 250 hours TT.
Clearance around the radiator is good, no rubbing.
Choose not to do SB 00088 due to the lack of wear signs.
Like others, my leak is small and isolated to the bottom two rows of fins on the right side (pax side) of the aircraft.
Have emailed Vans to notify.
Calling to order the new style radiator/SB kit tomorrow...assuming they are even available.
Just an FYI for anyone waiting or planning on ordering the new radiator (EA RV12IS RADIATOR-1). Placed my order with Vans this morning. Was given an approximate date of August 15th for the next batch arriving at Van's.
Well darn, my radiator sprung a leak - bottom front pilot side - 252 hours - SB done at 240 hours.
Just called Vans. Not expecting any new ones in until mid October! :(
